Results 1 to 4 of 4
Thread: Graphical Column Schedule
    September 15, 2018
    6
    10:51 AM
    Question Graphical Column Schedule
    Hello there,
    I cannot see columns in Graphical Column Schedule from linked files,
    Can you help me, please?
    There is big project, and one main model, where is linked other parties, and this Graphical Column Schedule shows nothing.
    Thanks
    Senior Member
    December 16, 2010
    849
    04:51 PM
    the columns are PROBABLY modeled as architectural columns - ie non load bearing.
    Im thinking the column schedule only shows load bearing elements, although I dont have it open right at this moment to check
    September 15, 2018
    6
    10:51 AM
    Thank you Dear Karalon10,
    I am talking about my model, which is Structural part and all columns are bearing, but as I guess Column Graphical Schedule does not work when linked file
    Senior Member
    December 16, 2010
    849
    04:51 PM
    ah yes I failed to see the important words here "linked files". no i can not create a column schedule from the linked file. I can however copy/monitor the columns from the linked file and then create one.
  1. Graphical Column Schedule
    By jjvapas in forum Structure - General Questions
    Last Post: August 10th, 2015, 02:58 PM
  2. Graphical Column Schedule Warning/Error
    By ms_ba in forum Structure - General Questions
    Last Post: October 17th, 2014, 10:02 PM
  3. Graphical Column Schedule too large to fit on one sheet...
    By LeanneZ in forum Structure - General Questions
    Last Post: September 9th, 2014, 03:47 PM
  4. Graphical Column Schedule Dimensioning
    By cordell in forum Structure - General Questions
    Last Post: January 17th, 2013, 05:37 AM
  5. Graphical Column Schedule Location Callouts
    By mscc01 in forum Structure - General Questions
    Last Post: August 20th, 2012, 11:33 AM
Tags for this Thread
