Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: Visibility of Modelled Component
    March 11, 2016
    18
    10:41 PM
    I've modelled a component in place. It's quite a complicated one for a sort of bay window. I've come back to one of my plan drawings and the modelled component is not showing properly. I have another plan drawing with the same view template which has less notes and dimensions and it shows in that one. I've tried revealing hidden items but that's not showing anything to do with my modelled component. I am at a loss as to how this has happened. I don't want to have to start again with a new duplicated plan because that's time consuming. The image below shows how it looks on the other plan - how it should look:-
    The bay window in front of the kitchen sink is perfectly visible. The following image shows how it's suddenly started to look on the plan I'm working on (bearing in mind it has the same view template):-
    Please help.
    Attached Thumbnails Attached Thumbnails Visibility of Modelled Component-how-should-look.jpg   Visibility of Modelled Component-how-does-look.jpg
    July 7, 2011
    Rotterdam, Holland
    1,278
    11:41 PM
    Well, that's hard to say from just those 2 images but 2 things come to mind:
    1. cut plane
    2. filters
    Look at your view template settings, it could very well be that the little tick box behind cut plane or filters is turned off, which makes those settings view specific again.
    And even in the one you say is correct, it looks to be off when you compare it to the other windows on the right side something is off with line weight.
    And then I have to ask, why did you do the windows as 'model in place' and not as a Window Family?
    cganiere likes this.
  1. One Component visibility is showing correctly, other is not
    By maddyjdelaney in forum Architecture and General Revit Questions
    Last Post: May 1st, 2018, 07:08 PM
  2. visibility detail component in family
    By peter smith in forum Architecture and General Revit Questions
    Last Post: April 16th, 2018, 10:54 PM
  3. adaptive component iso line visibility
    By redmonki in forum Architecture - Family Creation
    Last Post: January 11th, 2017, 01:22 PM
  4. Visibility Control of a Divided Surface Repeater Component
    By Barth in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 10th, 2016, 09:15 PM
  5. Legend component visibility / graphic overides...
    By Stephen S in forum Architecture and General Revit Questions
    Last Post: October 31st, 2011, 12:26 PM
