Results 1 to 5 of 5
Thread: Mirroring Beam system elements
    September 4, 2018
    Huntingdon
    2
    06:19 PM
    Is it possible to mirror elements in a beam system?
    I have roof decking which has been modelled in a beam system which i added to one roof slope but when i tried to mirror it i get an error message 'cant mirror element into this position'.
    Does anyone have a solution, or am i faced with modelling the opposite slope.
    Coeur d Alene, ID
    4,814
    10:19 AM
    If the beam system is attached to a roof slope then you need to mirror the roof too so the mirrored system is attached to something.
    Junior Member WelcomeToAccord's Avatar
    April 5, 2018
    Florida
    30
    01:19 PM
    Lightbulb
    On the other hand, if you detach the beam system from the roof and walls, etc., then you can mirror it without other components "interfering". When I model components from scratch, i try not to leave them connected or "bound" to other components unless I intend on doing so from the beginning.
    September 4, 2018
    Huntingdon
    2
    06:19 PM
    Thanks for the advice, being new to Revit and given the fact that the decking family was created by someone else I am not sure how to detach the decking from the structure other than unpinning is that what you mean?
    April 5, 2018
    Florida
    30
    01:19 PM
    Lightbulb
    Quote Originally Posted by peterlis View Post
    That's one step to detaching it, depending on the type of beam system it is. It might have a criteria under the properties pane that says "Room Bounding" which you should turn off and not check the box. If it doesn't have that parameter, then click on "Edit Type" and see if you can disassociate it from any other objects, or right click on the beam system itself and see if there's an option for "Do not allow join". If you want more specific help, then post your beam system family here, and I can try experimenting on my end.
  1. Select all elements of System Family
    By engineer in forum Dynamo BIM
    Last Post: February 8th, 2018, 02:36 PM
  2. How can I create a Beam System Tag to show Beam Type Mark or Beam Mark
    By gpktm in forum Structure - General Questions
    Last Post: September 10th, 2015, 04:44 PM
  3. Mirror elements in beam system
    By Exar Kun in forum Structure - General Questions
    Last Post: March 26th, 2014, 12:36 AM
  4. Mirroring a part of Project / Partial Mirroring
    By highta in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2014, 02:22 PM
  5. Default System over 50 Elements (in Revit Arch)
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: January 10th, 2011, 10:33 PM
