Results 1 to 3 of 3
Thread: Revit 2019 steel tab
    June 5, 2015
    88
    12:52 PM
    I just started to use Revit 2019 and my tools inside the Steel tab is not working.
    Am I missing anything?
    Coeur d Alene, ID
    4,814
    09:52 AM
    I noticed it is kinda finicky when selecting the structural elements...but I usually don't work with structural. Probably works best if you start with a structural template perhaps?
    Junior Member WelcomeToAccord's Avatar
    April 5, 2018
    Florida
    30
    12:52 PM
    Smile
    That's a good starting point. You can also download any updates and extensions related to steel components. If the tab still doesn't work, then I would report it as a bug on this forum and do a clean re-installation of Revit.
  1. Replies: 0
    Last Post: August 21st, 2018, 01:45 PM
  2. Replies: 0
    Last Post: May 2nd, 2018, 09:15 AM
  3. Replies: 0
    Last Post: March 21st, 2017, 11:45 PM
  4. Replies: 0
    Last Post: May 27th, 2016, 06:45 PM
  5. Revit for steel sheds and steel framed structures?
    By jake.b in forum Structure - General Questions
    Last Post: December 31st, 2014, 11:55 PM
Tags for this Thread
