Results 1 to 2 of 2
Thread: How custom analytical node xyz in floor circle
    October 1, 2011
    1
    06:44 PM
    Question How custom analytical node xyz in floor circle
    plaese, how edit analytical node with floor to make ramp circale. becasue in model analytical revit is flat floor, and i want analytical is slope. try modification the analytical node can to x and y, but to z not modification.
    December 11, 2010
    Astana
    87
    05:44 PM
    The sloped floor has a sloped analytical floor
  1. Dynamo at AU - Custom Dimension node
    By Raff in forum Dynamo BIM
    Last Post: February 7th, 2018, 07:24 PM
  2. Custom node definition is not loaded
    By Andrew P in forum Dynamo BIM
    Last Post: November 2nd, 2016, 10:06 AM
  3. Order of Input nodes for Custom Node
    By DaveP in forum Dynamo BIM
    Last Post: March 3rd, 2016, 11:53 AM
  4. Replies: 0
    Last Post: October 19th, 2015, 11:15 AM
  5. Replies: 0
    Last Post: November 18th, 2013, 11:45 AM
