Results 1 to 5 of 5
Thread: New filter selection option not active
    February 19, 2018
    Sri Lanka
    14
    11:16 AM
    Why cant I add objects by selecting to new filter group?
    Attached Thumbnails Attached Thumbnails New filter selection option not active-capture.png
    June 21, 2012
    Tours, France
    895
    06:31 AM
    Quote Originally Posted by wimal View Post
    That's normal , you need to add the objects after the filter creation
    February 19, 2018
    Sri Lanka
    14
    11:16 AM
    Thanks for the reply. But still I could not activate Select
    November 17, 2011
    35
    01:31 AM
    The integration of Selection Sets and filters is confusing. You can use either a selection set or a Rule-base Filter to apply graphic overrides, but the command to create them is different.
    To create a selection-based filter (selection set), go to the Manage tab>Selection panel>Edit.
    This will allow you to create a new selection set, which you can then apply a graphic override to.
    (If you have the elements selected already, the "Save" Selection Set command on the manage tab will become active. It also shows up on the Modify/Contextual tab for selected elements, next to the filter button.)
    Joe
    February 19, 2018
    Sri Lanka
    14
    11:16 AM
    Quote Originally Posted by Joe_Charpentier View Post
    Joe
    Thanks for your explanation.
  1. Replies: 0
    Last Post: October 25th, 2016, 04:15 AM
  2. Apply view filter to all links but not active file
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: August 27th, 2015, 02:58 PM
  3. Pre-Filter Selection (YeahSo Add-In)
    By cellophane in forum Third party Add-Ins, API and R&D
    Last Post: May 11th, 2013, 02:32 AM
  4. Replies: 0
    Last Post: January 15th, 2013, 03:15 AM
