Results 1 to 3 of 3
Thread: structural framing library does not show angles
    February 10, 2017
    2
    09:31 AM
    How do I load angles that are not in the structural framing folder for braces?
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    248
    10:31 AM
    The angle framing element should be located in the following directory on your local C: Drive
    C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Structural Framing\Steel
    The family file name is "L-Angle.rfa"
    The file path may vary depending on which version of Revit you're using, and whether you're needing metric or imperial families.
    February 10, 2017
    2
    09:31 AM
    Knittro87:
    Thanks for the reply. I was inquiring concerning R2018. That file was not in the library it was supposed to be. I thought I may have missed something.
    You gave me an idea though I just copied the needed file from 2017 to 2018 and 2018 converted it when I opened it to load the family.
    thanks again
  1. How to show my levels in framing elevation???
    By rishie in forum Architecture and General Revit Questions
    Last Post: June 8th, 2017, 04:03 PM
  2. Help w/ Structural Framing
    By mdomer in forum Structure - Family Creation
    Last Post: May 13th, 2016, 12:11 PM
  3. How to copy/monitor structural foundation and structural framing?
    By michalnykiel in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 01:37 PM
  4. Replies: 0
    Last Post: May 2nd, 2015, 01:18 AM
  5. Show hidden framing lines in elevation?
    By Defiant1 in forum Structure - General Questions
    Last Post: December 17th, 2012, 04:28 AM
