Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Concrete column schedule with NO grid
    August 5, 2017
    18
    05:40 AM
    Hi everyone,
    in our office, we have never been used the grid for concrete buildings but we use coordinate system X:Y for any element shown (see attached pic).
    1) Is there any way to manage column schedule with the number that I apply for each column?
    2) Is it possible to delete in COL. SCHED. the row with coordinates and add the row that will contain a number of a column? (see attachments how bad it looks)
    Thank you
    Attached Thumbnails Attached Thumbnails Concrete column schedule with NO grid-1111coord.jpg   Concrete column schedule with NO grid-colshed.jpg
    Junior Member NathanMorgan's Avatar
    August 1, 2017
    South Africa
    14
    11:40 AM
    Right click on any of your columns at the top and select insert column.
    Select the schedule field on the right and click the arrow to the left to remove it from your schedule.
    If you don't come right let me know and I'll look for another method but that should work
    Regards
    August 5, 2017
    18
    05:40 AM
    Thanks for reaching back,
    1) I didn't get your idea. Do you mean "column" as a concrete column or a column related to column schedule?
    2) The column schedule can't be generated at all because there are no physical columns attached to the grid because in my project the grid doesn't exist.
    August 1, 2017
    South Africa
    14
    11:40 AM
    Quote Originally Posted by arcticnyc View Post
    1) I meant the column in the schedule itself.
    2) however, if the column schedule can't be generated it might be due to the fact that the model is a linked file. It's only happened once with me I redrew the grids and everything was fine however this was in the beginning of the project I'm not sure how far into the project you are and if this method will work.
    August 5, 2017
    18
    05:40 AM
    I got your point but this is a new project. I wonder how people make concrete column schedules in concrete buildings. Usually, in our projects, no columns are aligned or colinear due architecture layouts, rooms, toilets etc. Even a small project would lead to hundreds of grids by a number and by a litera, too. That is why we use coordinates and it looks very accurate.
    February 28, 2017
    2
    05:40 AM
    Revit Structure Concrete Grapical Column Schedule without Grids
    We also are currently trying to provide a graphical column schedule using Revit Structure with no grids. This seems to be a NY city standard. Our plans will have concrete columns with a column identifier for each column, 1, 2, 3, etc.. The columns will be located using coordinates based on a hold point family in the column. Column 1 will be identified with the mark "1" and so on. I placed a simple grid with one intersection on my plan and had "include off-grid columns" checked in the schedule properties and this generated the entire column schedule with off column dimensions, obviously not what I want, nor in the correct order but did include the columns and levels.
    What I need is;
    The columns to be on the schedule in the order they are marked, 1,2,3,4
    Has anyone one been able to accomplish this with using Excel?
    Thanks!!!
    August 5, 2017
    18
    05:40 AM
    Ken, I think that Dynamo would be helpful here but I am still learning it at least to help me with a column schedule.
    I already did this 1, 2, 3, 4 etc. marks I have created a column tag and shearwall tag SW... with the "comments" as the only field to modify. When I choose a concrete column/shearwall it is easy to rename it in properties without opening any windows.
    February 28, 2017
    2
    05:40 AM
    Thank you
    Thanks for your reply, we are starting to use Dynamo as well however very green. I was hoping we cold use Revit alone to accomplish this. I've seen some column schedules by other NY structural engineers and they used AutoCAD and linked them in.
    February 6, 2016
    5
    05:40 AM
    Any new updates to this thread? Also a NYC based firm here, also with the same issue of having columns identified via a coordinate system that is non-linear (often) and preferably identified by numbers (1, 2, 3 ..... n)
    Any success with utilizing Dynamo? We have tried the ACAD Link as McCarron pointed out some firms do, but we still find that workflow cumbersome
    August 5, 2017
    18
    05:40 AM
    Nope, I applied Excel in a dumb way. Still trying to squeeze something from dynamo.
  1. Concrete Column Schedules
    By LeanneZ in forum Structure - General Questions
    Last Post: October 31st, 2017, 04:16 PM
  2. Concrete beam and column connections
    By matpog in forum Structure - General Questions
    Last Post: June 29th, 2016, 06:29 AM
  3. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  4. Merging concrete column to concrete wall?
    By craiglarkin in forum Structure - General Questions
    Last Post: January 16th, 2013, 04:52 PM
  5. Graphical Column Schedule Grid Linewights
    By Lambolica in forum Structure - General Questions
    Last Post: December 18th, 2012, 03:05 AM
