Donate Now Goal amount for this year: 3000 USD, Received: 2290 USD (76%)
Results 1 to 4 of 4
Thread: Column Schedules With Bent Member
    February 18, 2012
    29
    09:11 PM
    Hello,
    We have a situation where we have a column that will have a bend in it. However our column schedule shows the bent beam(good) but also shows a solid line for it going straight up(bad). Please see attached. How can we solve this to show the bend?
    Any ideas are greatly appreciated.
    Thank you
    Attached Thumbnails Attached Thumbnails Column Schedules With Bent Member-capture.jpg
    February 18, 2012
    29
    09:11 PM
    Just thought I would bump this to get more exposure. Thank you.
    Senior Member
    December 16, 2010
    746
    11:11 AM
    turn off "analytical model" in your graphic options, also edit the family and set that centreline (the straight one) which seems like a detail line to me to not be visible at "high" detail level and then set your view to high detail, that should hide it for you.
    February 18, 2012
    29
    09:11 PM
    Quote Originally Posted by Karalon10 View Post
    Thank you for the reply. We discovered it was actually that we needed to change the Family Category Parameters for Symbolic Representation to "From Family". Once we had that... it was golden.
  1. Concrete Column Schedules
    By LeanneZ in forum Structure - General Questions
    Last Post: October 31st, 2017, 04:16 PM
  2. Graphical Column Schedules
    By LindseyMcLaughlin in forum Architecture and General Revit Questions
    Last Post: October 24th, 2016, 06:43 PM
  3. Graphical Column Schedules
    By LindseyMcLaughlin in forum Structure - General Questions
    Last Post: October 24th, 2016, 01:38 PM
  4. Graphical Column Schedules
    By rhenryunh in forum Structure - General Questions
    Last Post: November 14th, 2014, 01:25 PM
  5. Manipulating Graphical Column Schedules
    By MartinGT in forum Structure - General Questions
    Last Post: February 19th, 2014, 03:12 PM
Tags for this Thread
