Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Results 1 to 2 of 2
Thread: Capatalize Column Location in GCS
    September 13, 2012
    1
    05:07 PM
    I'm looking for a solution for the Graphical Column Schedule (GCS). The GCS automatically has the "Column Location" text built in, however it is not capitalized (COLUMN LOCATION). Is it possible to change this?
    Member Darius's Avatar
    May 6, 2013
    465
    06:07 PM
    No i dont believe so this appears to part of the Graphic Column schedule and not editable
    Its pulled from the text apperance in the properties panel
  1. Adding Column Location Mark to Multi-Category Schedule
    By tunaogut in forum Structure - General Questions
    Last Post: July 15th, 2015, 02:34 AM
  2. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  3. Graphical Column Schedule Location Callouts
    By mscc01 in forum Structure - General Questions
    Last Post: August 20th, 2012, 11:33 AM
  4. Split sloping beam into 2 beams at column location
    By m77cck in forum Structure - General Questions
    Last Post: August 16th, 2012, 08:33 AM
  5. Revit OpEd: Location, Location and Location
    Last Post: August 26th, 2011, 03:00 PM
