Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree2Likes
Thread: Join geometry
    May 29, 2015
    7
    09:57 AM
    Join geometry
    hello fellow Revit users
    once upon a time when I used the join geometry tool ( same material ) I got a clean shape however now I get a thin line showing where the geometry was joined. ( please see pic)
    what exactly controls this thin line in OBJECY STYLE?
    how can I get rid of it without using the invisible line work tool?
    please help
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    03:57 AM
    Just a thought, but is it because the two walls touch but are not connected? Using the "disallow join" on the end of the wall but going back with the join tool without realizing it?
    I'm able to reproduce it in my model and that seems to be "a cause" but it might not be your cause of the issue.
    May 29, 2015
    7
    09:57 AM
    Quote Originally Posted by rbcameron1 View Post
    hi there,
    even in the case of two walls I get the same thin line when they are allowed to join.
    and my apologies for not mentioning,
    the image above is a section of a conc. wall attaching to conc. floor
    thanks and cheers
    UKN
    UKN is offline
    Member UKN's Avatar
    February 16, 2011
    Las Vegas, NV
    58
    02:57 AM
    Is it because it's two different materials? If you join elements with different materials you will get a line between the two materials. Edit: Never mind, just saw that you said they were the same material.
    cganiere likes this.
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    630
    10:57 PM
    One item Structural the other not?
    May 29, 2015
    7
    09:57 AM
    hi all
    same material, both structural and still see that UUGHHH line.
    all good points, need more
    cheers
    - - - Updated - - -
    hi all
    cheers
    March 21, 2011
    Brisbane
    284
    07:57 PM
    It could be the depth of your section. ie it is 'deep' enough to pick up a slab edge and the line you see is hidden line of the edge.
    Senior Member
    December 16, 2010
    845
    07:57 PM
    It is my opinion that you have a slight difference in your view range where one object goes deeper, or higher than the other.
    ie. go to elevation, and see if the object stops at the bottom/top of the other object or if it continues past.
    You will often see this kind of thing when you have a really slight difference in these objects.
    November 3, 2015
    24
    09:57 AM
    Hi guys
    Any idea how to join this curved wall in the middle to the others so the lines disappear and the windows cut ? Join geometry works on walls that are in straight line but I'm having trouble with the curved one ?
    June 21, 2012
    Tours, France
    896
    10:57 AM
    Hi HSG11, to make the lines disappear you can use the line modifier tool you have in Modify - View (See Image),
    There is also the Join geometry tool you can use for this specific case,
    secondly for the window cut maybe the modify wall boundary can help you, regards
  1. Join Geometry: Counter-intuitive, Counter-productive and...
    By Barth in forum Architecture and General Revit Questions
    Last Post: July 26th, 2017, 07:40 AM
  2. Phase, join geometry problem
    By srwsl in forum Architecture and General Revit Questions
    Last Post: March 19th, 2014, 07:37 AM
  3. join panels / remove join line
    By ledgehead in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 28th, 2013, 01:28 AM
  4. Void Vs Opening w/ Hosts + Join Geometry + Family Templates...
    Last Post: October 18th, 2012, 05:22 PM
  5. join Geometry problem
    By Nsync in forum Architecture and General Revit Questions
    Last Post: March 30th, 2012, 10:10 PM
