Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Like Tree2Likes
Thread: Join geometry
  1. #11
    November 3, 2015
    24
    06:58 AM
    Ok that works, but the windows don't cut through the other wall (see image) ?
  2. #12
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,005
    08:58 AM
    Hi HSG11; ok Yes, I get it, the cut problem is because the window can cut just one wall at time or at least the second one will have the type of behavior you are experiencing , the problem for the second wall opening is that Revit can't edit curved wall's shape as the same way it does with the straight ones , so in order to achieve your need! you must add to the second wall an opening or at least I'll try that (see image) , hope this helps, regards
    Attached Thumbnails Attached Thumbnails Join geometry-fenet.png   Join geometry-fenet2.png
  3. #13
    November 3, 2015
    24
    06:58 AM
    haha I was just on my way to post the same solution. Wall opening + LW (invisible) looks good in elevations. Thank you very much
    Andres Franco likes this.
  4. #14
    June 21, 2012
    Tours, France
    1,005
    08:58 AM
    haha, that's I call team work!!! , your welcome!!!
  5. #15
    November 3, 2015
    24
    06:58 AM
    One more thing. I have windows created with curtain walls in all the straight walls but I have to put regular revit windows (WN) in the curved wall (because the windows are not curved). If i wanted to use curtain walls there I would then have to place a wall opening on every window right ? or is there any other way ?
  6. #16
    June 21, 2012
    Tours, France
    1,005
    08:58 AM
    No, you just need to use the "cut geometry" tool and that's all!!
  7. #17
    November 3, 2015
    24
    06:58 AM
    Hmmm ... it wont cut ?
  8. #18
    June 21, 2012
    Tours, France
    1,005
    08:58 AM
    Hi HSG11, Sorry for the delay to respond I was quite busy , to solve that, first try to align to the center of your structural wall and then try to cut with the cut geometry tool, that should work if doesn't we'll try another thing, regards
  9. #19
    November 3, 2015
    24
    06:58 AM
    Can't align (AL). Revit gives me two lines to draw after but when I chose the inner line I get this error (image "gl1").
    Attached Thumbnails Attached Thumbnails Join geometry-gl2.jpg   Join geometry-gl1.jpg   Join geometry-gl3.jpg
  10. #20
    June 21, 2012
    Tours, France
    1,005
    08:58 AM
    Hi, when you get that message you just let Revit erase the mullion, you can add it after by using - Architecture - Mullion and the you just pick the line for your mullion (see image)
    Attached Thumbnails Attached Thumbnails Join geometry-1.png   Join geometry-2.png   Join geometry-3.png   Join geometry-4.png
  1. Join Geometry: Counter-intuitive, Counter-productive and...
    By Barth in forum Architecture and General Revit Questions
    Last Post: July 26th, 2017, 07:40 AM
  2. Phase, join geometry problem
    By srwsl in forum Architecture and General Revit Questions
    Last Post: March 19th, 2014, 07:37 AM
  3. join panels / remove join line
    By ledgehead in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 28th, 2013, 12:28 AM
  4. Void Vs Opening w/ Hosts + Join Geometry + Family Templates...
    Last Post: October 18th, 2012, 05:22 PM
  5. join Geometry problem
    By Nsync in forum Architecture and General Revit Questions
    Last Post: March 30th, 2012, 10:10 PM
