Results 1 to 2 of 2
Thread: Concrete beam and column connections
    June 29, 2016
    1
    07:38 PM
    I have a concrete beam and column conncetion problem: both connect like on left picture., but I want to have connection like on right picture? It's possible with standard Revit structural beam and column families?
    Senior Member
    December 16, 2010
    864
    05:38 AM
    It's possible to have the right picture type connection.
    Your column appears to be connected to a roof, giving it a tapered / chamfered top surface.
    Either it is attached at the top, or your column family has this shape built into it, but I would guess you have attached the column to the roof line or a reference plane.
    Disconnect it from whatever is causing the chamfer at the top and you will have a flat surface and a square finish.
  1. Beam to Beam or Beam to Column Join Method
    By dedo in forum Structure - General Questions
    Last Post: March 15th, 2018, 11:59 AM
  2. Replies: 0
    Last Post: June 14th, 2016, 06:45 PM
  3. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  4. Merging concrete column to concrete wall?
    By craiglarkin in forum Structure - General Questions
    Last Post: January 16th, 2013, 03:52 PM
  5. Replies: 0
    Last Post: January 8th, 2013, 01:15 PM
