Donate Now Goal amount for this year: 3000 USD, Received: 2527 USD (84%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Exporting / printing schedule to PDF
    August 25, 2015
    34
    12:55 PM
    I've looked into this the entire afternoon, but couldnt find a solution. I would really want to be able to print (or export) a schedule to pdf.....including my type-images. I've seen Sofistik has this wonderful function for bending-schedules (Structural detailing 2016). The best i've come up with is exporting to excel, but then all the images become text...and i really need those images.
    thnx.
    November 11, 2013
    213
    06:55 AM
    To "print" (so, send to PDF) it needs to be placed on a sheet. Place it on a sheet and print it to PDF from there.
    August 25, 2015
    34
    12:55 PM
    i know, but i want my schedule printed on A4, and sometimes it will be counting 50 to 100 pages....so placing it on a single page isnt really an option.....i think?
    November 11, 2013
    213
    06:55 AM
    Don't think you really have any other options ... images in a schedule will only display on a sheet, especially. :/
    March 3, 2016
    179
    12:55 PM
    You will have to create a separate A4 sheet for every page and split a schedule in a schedule view to get 50 parts of it or you can save some work and try to do something like that:
    1. Create sheets with multiple titleblocks - copy titleblocks on a sheet and place them in a row, let's say 5 of them. The print area should be then (5x 210 mm) x 297 mm. If you need 50 A4 drawings, then you will need only 50/5=10 sheets.
    2. Place a schedule on a sheet and split it. Drag series of 5 parts to fit within printing area of 5 titleblocks.
    3. Copy splitted schedule to every sheet and adjust position of splitted schedule parts accordingly.
    4. Print to pdf. Now you can try to split pdf file into 5 separate A4 pages or leave it.
    August 25, 2015
    34
    12:55 PM
    I might give that last one a try, tho i guess its still is quite time-consuming. Thanx for your help.
    June 10, 2017
    2
    11:55 AM
    I believe you should be able to find that in the Autodesk App Store. In fact there is a plugin called Reports that does that.
    Senior Member
    December 16, 2010
    750
    09:55 PM
    also just to add that the sofistik plugin (for reo) is free.
    the analysis package that goes with it will cost you a kidney though
    Member Mr_Greg's Avatar
    April 13, 2012
    Glenside, PA
    154
    07:55 AM
    Couldn't you export the schedule to a .txt file then import to Excel and make pdf's from that?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,251
    04:55 AM
    Quote Originally Posted by Mr_Greg View Post
    not with Type images included which was a part of the OP's request
  1. 3D view exporting/printing problems
    By Aleksander in forum Architecture and General Revit Questions
    Last Post: November 21st, 2015, 07:10 PM
  2. exporting schedule to DWG
    By billiam in forum Architecture and General Revit Questions
    Last Post: January 30th, 2015, 03:51 PM
  3. Replies: 0
    Last Post: November 21st, 2014, 06:15 AM
  4. Exporting a model to DXF without exporting hidden elements
    By bshara in forum Third party Add-Ins, API and R&D
    Last Post: April 28th, 2014, 05:57 PM
  5. Replies: 0
    Last Post: July 28th, 2011, 06:10 PM
