Donate Now Goal amount for this year: 3000 USD, Received: 2345 USD (78%)
Results 1 to 4 of 4
Thread: Adding Column Location Mark to Multi-Category Schedule
    July 8, 2015
    2
    06:31 AM
    I need to copy the Column Location Mark of each structural column to its Identity Data as a parameter. So I figured that if I could add the "Column Location Mark" to a "Multi-Category Schedule" as a column, I could somehow be able to copy the values in that column to the column of the parameter I place under Identity Data. Graphical Column Schedule doesn't work for me since I need to be able to list Column Location Marks in columns.
    July 8, 2015
    2
    06:31 AM
    Is there really no solution to this? Lots of views but still no reply? Because I really need to find out how to solve this
    July 20, 2011
    781
    11:31 PM
    looks like Column Location Mark is hardcoded at project level, seems API can get access to that parameter, don't know if Dynamo can?
    Attached Thumbnails Attached Thumbnails Adding Column Location Mark to Multi-Category Schedule-column-location-mark.jpg
    July 20, 2011
    781
    11:31 PM
    Column Location Mark is available in struc column schedule, to make it available in multi-category schedule, you may have to create shared parameter and "copy" value from Column Location Mark
  1. Multi Category Schedule External Windows and Doors
    By timmos1983 in forum Architecture and General Revit Questions
    Last Post: September 28th, 2016, 07:27 PM
  2. Multi-Category Schedule grouped by System Name?
    By tzframpton in forum MEP - General
    Last Post: September 1st, 2016, 12:42 PM
  3. Multi category schedule filtered by family type
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: April 11th, 2013, 05:42 AM
  4. Multi-category schedule
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: September 12th, 2011, 08:37 AM
  5. In-Place Family Parameter in Multi-Category Schedule?
    By narlee in forum Architecture and General Revit Questions
    Last Post: August 25th, 2011, 09:22 PM
Tags for this Thread
