Results 1 to 3 of 3
Thread: Order of items in floor material takeoff schedule
    April 6, 2015
    1
    08:53 AM
    Hi all
    I've done a search here and on Google, but nothing showing up.
    I've created a floor type using the correct method, the assembly has 7 layers. The view is great and it goes onto a sheet perfectly. I want to schedule the layers in this assembly by layer and thickness rather than keynoting, tagging or text noting them. I've done that fine, using Vol / Area to get the thickness, actually (frustrating in itself). However, the order of the items in the schedule is not the order in the assembly. I have no idea what is determining the order. I can force the order once only by setting the material mark, say, for each material layer to 1 ,2 ,3 ,4 ,5 etc, and sorting by that parameter, but the next floor type requires a different order, and so I have to use different materials, as the marks are set per material. An example would be dpm above slab, dpm below slab: requires two dpm materials, one with a higher mark value than the slab, one with lower. This is a horrid and laborious workaround.
    This is frustrating as the layer has a number in the assembly, but it's not accessible in the schedule builder.
    Nor is it possible to insert a shared or project parameter into the schedule with a unique value per line: they all change at once.
    What sets the order of the items in the material takeoff schedule and is there a way of controlling it without having new user materials unique to each wall type?
    Thanks!
    vza
    vza is offline
    July 26, 2017
    4
    07:53 AM
    I'm trying to do the same but with a wall material takeoff schedule. I want to set the order of materials to the wall assembly or set them manually without creating a lot of duplicated materials. What did you end up doing?
    December 11, 2010
    Astana
    117
    01:53 PM
    Create several shared parameters: Layer 1, Layer 2 ... Layer X, then use Dynamo to fill the parameters. If there are not many types, you can do it manually.
    Or try Revit Parts.
  1. Quantities or Material Takeoff, material costs and thermal values
    By alfakappa in forum Architecture - Family Creation
    Last Post: August 22nd, 2014, 10:34 AM
  2. Material Takeoff
    By gdoherty0102 in forum Structure - General Questions
    Last Post: September 25th, 2013, 06:39 PM
  3. get Ramp material info. for material takeoff purpose
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: April 15th, 2013, 07:02 AM
  4. Material Takeoff Schedule
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: September 25th, 2012, 05:18 PM
  5. Material Takeoff
    By anjali in forum Architecture and General Revit Questions
    Last Post: July 30th, 2012, 01:37 PM
