Results 1 to 5 of 5
Like Tree3Likes
  • 3 Post By ryntau
Thread: Glazed panel appearance issue...
    January 13, 2015
    3
    02:18 AM
    Question Glazed panel appearance issue...
    Hello,
    I want to change the appearance of one storefront curtain wall( with glass material). At the same time other entities with glass material should change their appearance. I tried o duplicate the glass material (for a single curtain panel) but, it did not worked out well. Please suggest the appropriate solution.
    June 11, 2014
    Abu dhabi, UAE
    46
    12:48 AM
    System panel
    Quote Originally Posted by thatsnagesh View Post
    Hello,
    Hi
    You need to duplicate the system panel and create a new one and then assign a duplicated material.
    Select a glazed panel unpin it and then duplicate it.
    January 13, 2015
    3
    02:18 AM
    @ vivek,
    I tried the same. but duplicated material takes the assigned values of old(original ) material & hence, any change in the new material gets into the old one.
    Now, I do not know is it a bug or something else.
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    01:48 PM
    @ vivek,
    You'll need to duplicate the Asset as well as the material in order to have completely distinct materials. You'll notice that under the Appearances Tab of new materials there is a little hand with a number 1, saying that one other material shares that asset. Way over to the right of that screen, you'll see two buttons, Replace this asset, or Duplicate this asset. If you hit Replace, you'll be able to select from a huge list of material assets, if you hit duplicate, you'll get to change the one you're working in without modifying the existing (the little number next to the hand will also disappear)
    Ning Zhou, vivek and thatsnagesh like this.
    January 13, 2015
    3
    02:18 AM
    @ryntau,
    happy to learn new key point in Revit. Thanx. But, still there is an same issue. I have duplicated the glass material for curtain wall. Now this material is not being used by any other element (theoretically). But when I insert a window with glass material, new window is having new properties as that of curtain wall glass.
  1. Revit 2015 R2 Reference Section Panel Issue
    By Alexander_Odessa in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 09:43 AM
  2. Replies: 6
    Last Post: April 17th, 2013, 03:40 PM
  3. Butt-glazed corners
    Last Post: August 20th, 2012, 02:42 PM
  4. Bifold Glazed Door
    Last Post: August 7th, 2012, 01:17 AM
  5. Drop Panel Issue
    By alexo4141 in forum Structure - General Questions
    Last Post: May 21st, 2012, 12:29 PM
Tags for this Thread
