Results 1 to 2 of 2
Thread: Could i change family parameter to shared parameter?
    July 7, 2014
    27
    06:04 AM
    as the subject i made a family and used it in the project then i want to use one parameter for it in the filter i couldn't, i think i have to change it's type from family to shared so i can see and use it in the filter
    the problem now is after changing it in the family editor to shared and load it to the project, it's override all items in the model, i don't want it to change the item in the model & in same time i want to see the parameter after being shared to be able to use it in the filter.
    May 3, 2012
    1,403
    05:04 AM
    If you dont want to affect the existing parameter you can just add an extra shared parameter and then use New_Shared_Parameter = Existing_Family_Parameter in the family.
    So you still change the old parameter to set it but you can use the new parameter to filter or schedule.
  1. Change Shared Parameter?
    By DaveP in forum Architecture - Family Creation
    Last Post: October 30th, 2014, 03:01 PM
  2. Load Shared Parameter into Family via API
    By Patrick in forum Third party Add-Ins, API and R&D
    Last Post: August 13th, 2014, 01:21 AM
  3. Family Shared Parameter "Group Parameter Under" in a Project
    By Aretap in forum Architecture and General Revit Questions
    Last Post: August 10th, 2012, 10:18 PM
  4. Using "Family Type" Parameter as a Shared Parameter
    By jmwatson84 in forum Architecture - Family Creation
    Last Post: May 8th, 2012, 09:36 PM
  5. Convert Project Parameter to Shared Parameter
    By Rustle in forum Architecture and General Revit Questions
    Last Post: January 5th, 2011, 07:35 AM
