Results 1 to 5 of 5
Thread: Concrete beam to column connection
    May 12, 2014
    2
    04:06 PM
    Lightbulb Concrete beam to column connection
    Hi guys i,m facing a problem her i already make a new concrete column family it has the shape attached in the figure my problem here the connection between the new column and existing beam have a special distance and i can,t find a solution to this problem please help
    Thank in advance
    Attached Thumbnails Attached Thumbnails Concrete beam to column connection-beam-column-connection-problem.png
    Member Darius's Avatar
    May 6, 2013
    489
    09:06 AM
    Since you are using Revit 2014 there are properties in the beam called end join cutback and start join cutback that can adjust the beam cutting into the column (im guessing u don't want that vertical cut that appears next to the beam) if that does not work try using a reference plane to cut the beam.
    May 12, 2014
    2
    04:06 PM
    Thanks for your reply Darius i found the solution i have to edit the column family from family category and parameters (material and modal behavior) to concrete not the material only from family types after that the problem resolved and connection be normal
    September 13, 2014
    hyderabad, India
    2
    06:36 PM
    Thank you soo much Mr. Ahmed. banging head since yesterday about this problem. now i feel relaxed.
    Thanks once again.
    Best Regards,
    Imran
    September 13, 2014
    hyderabad, India
    2
    06:36 PM
    Hi Mr. Ahmed, i am facing the same problem again, even after changing the material and model behavior to concrete. now the problem is if i am connecting BEAM 1 to column then BEAM 2 automatically taking space from column and while am disconnecting BEAM 1 then BEAM 2 connecting exactly to column. Please help.Concrete beam to column connection-prob1.jpgConcrete beam to column connection-prob-2.jpg
  1. Is it possible to "unjoin" a beam and column connection?
    By ryntau in forum Structure - General Questions
    Last Post: May 8th, 2014, 10:14 PM
  2. Beam to Column Connection (RHS Sections)
    By gpktm in forum Structure - General Questions
    Last Post: October 13th, 2013, 10:14 PM
  3. Column to Beam Connection
    By gdoherty0102 in forum Structure - General Questions
    Last Post: October 24th, 2012, 12:08 PM
  4. beam-column connection
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: November 16th, 2011, 09:18 AM
  5. Stop Beam to Column Connection
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: November 15th, 2011, 08:54 PM
