Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By mark b
Thread: What is "Direction Line" in beam systems?
    Member gpktm's Avatar
    October 22, 2012
    Melbourne, Australia
    144
    08:05 AM
    Question What is "Direction Line" in beam systems?
    Hi everyone
    Exactly what the titles says. I would like to know what "Direction Line" is in beam system Pattern Justification.
    Thanks.
    Coeur d Alene, ID
    4,814
    02:05 PM
    The direction the beams go? (Horizontal vs Vertical or Angled)
    Moderator mark b's Avatar
    NSW Australia
    1,430
    07:05 AM
    In a beam system you can draw a "direction line" anywhere it doesn't have to be a part of the beam system boundry.
    If you then set "justification" to "Direction Line" then your spacing will start from the "direction line" placing a beam on that line and then in a direction parallel to that line and is not dependent on any boundry line.
    Also read here bottom of page
    Attached Thumbnails Attached Thumbnails What is "Direction Line" in beam systems?-beam-direction.jpg
    AHutchinson likes this.
    October 22, 2012
    144
    08:05 AM
    Beautiful... thanks mate!
  1. Beam Tags & Labels, not switching to "Type Mark"
    By Dseven24 in forum Structure - General Questions
    Last Post: October 16th, 2013, 11:07 PM
  2. Curtain Wall Q: How to turn off "auto grid line" function?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: May 1st, 2013, 08:10 PM
  3. "No Plot" line/obkect-style setting?
    Last Post: March 23rd, 2012, 04:35 PM
  4. beam/column join to create "rigid frame"
    By Scott Webb in forum Structure - General Questions
    Last Post: April 28th, 2011, 05:29 PM
  5. "Flpiping" Line based families
    By Alex Page in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2011, 10:02 PM
