Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree3Likes
Thread: Wall Openings
    Junior Member juangambino's Avatar
    February 8, 2012
    Leeds
    41
    10:40 PM
    Wall Openings
    Hello Everyone,
    I wondered which way (if any) is the correct way to create openings in a wall, I prefer using the family types, structural openings and create door types etc and host them in my walls, my colleague made a wall and amended his profile to trace around where the door would be, there is also wall opening located on the opening TAB?
    How do these methods behave differntly?
    Cheers
    Member Darius's Avatar
    May 6, 2013
    488
    05:40 PM
    there is a wall opening family in the door family folder i would highly recommend that for all doors since you can just switch the wall opening out for a door easily
    Tracing a wall opening in profile for this is counter productive as it will have to be removed to place your door, the wall profile i have always used for things such as stepped wall foundations or closing the gap on a roof for example an A frame roof
    The wall opening tool is more for things like conduits or pipes to pass through walls
    Be aware the wall opening tool can not be used to make things like beam pockets in walls those must be made with void familes in a beam or modeled in place void familes
    February 8, 2012
    Leeds
    41
    10:40 PM
    Cheers Darius,
    Indeed I always use the wall opening family, I was just wondering why ways are better, apart from the obvious changing of door opening family types will obviously be quicker throughout your project.
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    782
    05:40 PM
    Quote Originally Posted by juangambino View Post
    Hello Everyone,
    Cheers
    The lore I have been told about the wall opening tool is that is was created specifically for creating a wall opening in a wall that is curved in plan. There is no way to edit the profile of a wall curved in plan and a component(door) opening would work fine at smaller sized openings, but will not work so well if you need a bigger opening in a wall curved in plan. So that is why the "wall opening" tool was created way back in the early days of Revit.
    May 6, 2013
    488
    05:40 PM
    I think you mean Best Practices=Better way?
    I outlined some of my best practices above in the previous post I have found those ways to be the quickest for those items is there something specific that you are looking for
    December 21, 2010
    C.LONDON
    4,394
    10:40 PM
    I never use the (wall) opening tools - and delete them, without question, when I find them (like I do shafts* and ramps) - since they're incredibly dumb.
    Instead I use a selection of hosted-families (some by-wall/roof/ceiling, but most by-face) since "openings" (more often than not) are treated with fire-stops and such, and on occasions need to be dimension (centre, drill-point, of circular-pipework-builderswork) and even scheduled sometimes - all things the opening tools are useless for.
    *...but that's not to say I'm a stubborn-minded purist, since I'll actually use in-place voids on occasions to cut things - since they at least respect phases, and don't buckle shape-edited roofs & floors.
    As ever, it's all compromise - and finding what works for you for the entirety of your work.
    Mr. Revit OpEd
    2,952
    02:40 PM
    Like anything understanding their differences is important. For example if I need a round hole in a wall I could use a jigsaw, sawzall, Xacto knife, sledgehammer, hole saw, drill bit etc (or dynamite). Depending on the size of the hole I need any of those could provide a hole with varying degrees of accuracy, success and effort.
    Wall Openings in Revit apart from being a bit weird also affect room bounding differently than families that cut a wall.
    In the attached image:
    • Left side of Image: a Wall Opening doesn't respect (alters/affects) the bounding nature of the dividing wall
    • Center of image Image: a opening family does
    • Right side of Image: A wall opening allows area to extend "into" a host wall where a curtain wall needs to go while a curtain wall (top wall) that uses Automatically Embed (bottom wall) instead does not.
    • Added image (right image) shows same conditions but with using Edit Profile on the wall in the left side of the image.
    Attached Thumbnails Attached Thumbnails Wall Openings-openingdifferences.jpg   Wall Openings-openingdifferences02.jpg
    December 21, 2010
    C.LONDON
    4,394
    10:40 PM
    Quote Originally Posted by Steve_Stafford View Post
    Just out of curiosty; What was the view range cut plane? And the height of the opening, (both system and family) ?
    Mr. Revit OpEd
    2,952
    02:40 PM
    Cut Plane is stock imperial 4'-0" (1200mm ish) If the wall opening comes into contact with the Computation Height of the host level it "affects" the room bounding. Added a wall opening (like a window) to the middle building.
    Attached Thumbnails Attached Thumbnails Wall Openings-openingdifferences03.jpg   Wall Openings-openingdifferences04.jpg
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    02:40 PM
    Like anything understanding their differences is important. For example if I need a round hole in a wall I could use a jigsaw, sawzall, Xacto knife, sledgehammer, hole saw, drill bit etc (or dynamite). Depending on the size hole I need any of those could provide a hole with varying degrees of accuracy, success and effort.
    Steve, These are great and could become a nice blog post, as they do each have use cases.
  1. Does anyone know why I can´t see through wall openings in Eelevation?
    By audaxviator in forum Architecture and General Revit Questions
    Last Post: May 16th, 2015, 07:53 AM
  2. Openings in slanted wall
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: August 14th, 2013, 02:59 PM
  3. Creating windows in wall or roof openings?
    By smshiran in forum Architecture and General Revit Questions
    Last Post: April 10th, 2013, 01:30 PM
  4. Wall openings
    Last Post: November 28th, 2012, 01:11 PM
  5. 3=1 walls (where one is a curtain wall) + Openings
    Last Post: June 26th, 2012, 04:05 PM
