hi guys,
I wanted to ask you if the Extensions work properly.
for example, to me the Steel Connections not working properly, as, for example, it's impossible to decide the layout of the bolted connections between the beams and columns, or you can not size the plate with anchor bolts of the structural connection to the ground. The plate is not parameterized.
Some of you habitually uses the Revit Extensions?
sorry for my english this is google translator
