Results 1 to 4 of 4
Thread: Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    March 21, 2011
    Brisbane
    287
    06:54 AM
    I have created 2 slabs with 1/100 slope. 1 slab is using a "Slope Arrow" to define the slope while the other use slab "define slope" to create the slope.
    If I enter these numbers (0.572938697683) to define the slope in both slab I actually get a discrepancy between them. It seems that when you use a slope arrow the numbers are actually rounded off to 0.570. The discrepancy is not much but it is a discrepancy nonetheless.
    Anyone ells encountered this using RST 2011?
    Cheers,
    J
    Attached Files Attached Files
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    01:54 PM
    I personaly do not use a slope, or define a slope anywere on my drawings. This goes back to the discussion on build it in Revit how they will build it in the real world. I define my slope with a reference plane. Then draw my geometry and use the model to get my heights. Most of the time we round up to nice round TOS, TOC number and forgo the slope, saying 1/2" : 1'-0" SLOPE MIN. This also makes it WAY eaiser when you have to adjust your framing or concrete.
    March 21, 2011
    Brisbane
    287
    06:54 AM
    We use ref plane for all rhe framing, components etc.
    But how do you actually use a ref plane for a slab/floor? If you have the work plane set to a ref plane and then try to model a slab you get a warning message saying "this work plane can't be used for this operation".
    Cheers,
    J
    December 8, 2010
    Northern California
    3,567
    01:54 PM
    I dont associate my roof to the RP, i use the RP to get snap points for heights.
  1. Replies: 3
    Last Post: March 18th, 2016, 10:32 PM
  2. beam/column join to create "rigid frame"
    By Scott Webb in forum Structure - General Questions
    Last Post: April 28th, 2011, 05:29 PM
  3. Sharing Content - Common RFO "Style Guide" ?
    By Munkholm in forum Architecture - Family Creation
    Last Post: February 25th, 2011, 08:48 AM
  4. Revit 2011 - "Black rendering" with Non-English Win XP
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: January 10th, 2011, 08:15 AM
  5. Replies: 2
    Last Post: January 7th, 2011, 06:19 PM
