Results 1 to 9 of 9
Thread: Bar mark annotation drag grip??
    January 8, 2013
    Leeds, England
    75
    06:31 AM
    Hi, is It possible to adjust the length of the line as shown in my pic. attached using a grip? at the moment I have added a length parameter, however if I want to adjust the line I have to go into 'edit type' and change the length in there, which changes the length for all that type??? it would be great if I could just click on a grip and change the length as I wanted. any help would be much appreciated. ThanksBar mark annotation drag grip??-barmark-annotation-revit.png
    Senior Member alexo4141's Avatar
    May 25, 2011
    Québec, Canada
    548
    01:31 AM
    There's a way to add grips to generic annotation family but they cannot be used in scaled views.
    However, you could nest the text and the arrow in a detail component and control the length of the line with a grip.
    January 8, 2013
    Leeds, England
    75
    06:31 AM
    The text is a schedule mark tag, how would I create the detail component to control the length of the line with a grip as you mentioned?? (thanks for the reply)
    May 25, 2011
    Québec, Canada
    548
    01:31 AM
    Is it a tag or a generic annotation?
    January 8, 2013
    Leeds, England
    75
    06:31 AM
    its a tag...
    January 8, 2013
    Leeds, England
    75
    06:31 AM
    Also, if you were to create 2 completely different concrete structures within the same project file (thus 2 separate drg sheets and schedules required), how would you filter the bars to create 2no. schedules? would you do it with 'phases' or 'assemblies'??
    United States
    1,141
    11:31 PM
    Depends on what version you are using. Prior to 2013 I would recommend adding a parameter to filter schedules by. 2013 and after just use assemblies.
    January 8, 2013
    Leeds, England
    75
    06:31 AM
    thanks gdoherty, I am on 2014 and found using assemblies is very easy to filter schedules. I am however have problems with taking into account bending/cutting tolerances in my schedule. Obviously the dimensions it creates are based on covers, is there a way (e.g. a tick box or something similar) of taking off an extra 10/15/20/40mm for bending and cutting tolerances off the bars, without physically changing the bar dimensions manually? How do you guys go about this?
    United States
    1,141
    11:31 PM
    We typically will model to the lenghts we want fabricated. However, in 2014 they added a bar rounding that you can adjust in the Rebar preferences.
  1. section mark still show up way beyond crop region and annotation crop
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: November 5th, 2017, 05:42 PM
  2. Grip Colour
    By DD1 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 10:41 AM
  3. How do I add a grip and a flip parameter to an annotation?
    By matfloyd2008 in forum MEP - Family Creation
    Last Post: October 1st, 2012, 03:23 PM
  4. Replies: 0
    Last Post: January 27th, 2012, 01:15 PM
  5. Revit OpEd: Dept. of Flashback - Mark and Type Mark
    By Blog Fetcher in forum Blog Feeds
    Last Post: June 21st, 2011, 07:00 AM
