Results 1 to 4 of 4
Thread: Steel Staircase
    January 16, 2013
    2
    10:23 AM
    Steel Staircase
    Is there a way to create a stair that uses structural components ie: channel stringers, steel pans and concrete treads, without creating each individual piece and placing it along the stair path? I need to cut sections through stairs to detail them.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    12:53 AM
    Quote Originally Posted by Sushobhan View Post
    In your stair properties you can assign a profile to the various parts.
    Attached Thumbnails Attached Thumbnails Steel Staircase-stair-properties.jpg   Steel Staircase-stringer.jpg
    Member RsqPrincess's Avatar
    October 3, 2011
    Wisconsin, USA
    60
    11:53 PM
    I don't work a lot with modeled stair systems, but from my experience you can use structural components in the way of "profiles".
    If you are using an "assembled stair" (as opposed to the monolithic or precast stairs), you can go into the type properties. To change the stringer type, you'll click on either "right support type" or "left support type" which should open a new box "System Family: Stringer". In this box you can change the stringer information, such as profile and materials. You may need to import more profiles into your project in order to get the structural component you'd like.
    Back in the type properties of the stairs, if you click on "run type", it should take you to a window where you can change both nosing and tread profiles, as well as other information.
    Once you load these components in and create your stair type it will go much faster in the future.
    I hope this at least helped a little!
    March 21, 2011
    Brisbane
    288
    02:53 PM
    Another way is to use the Railing for the stringers. Then you can load/use any profile you like.
    jh
  1. Staircase Problem
    By andreakset in forum Architecture and General Revit Questions
    Last Post: February 20th, 2018, 05:18 PM
  2. Cold Formed Steel - Steel studs
    By kev4174 in forum Structure - General Questions
    Last Post: August 27th, 2013, 12:24 PM
  3. Staircase issue
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: February 15th, 2012, 01:17 AM
  4. Staircase & Railing
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 09:28 AM
  5. Staircase
    By Kcooke in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 09:25 AM
