Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: I need a reinforcement add in
    February 15, 2012
    78
    06:51 AM
    I need a reinforcement add in to Revit 2013
    Moderator LeanneZ's Avatar
    December 8, 2010
    Charlotte, NC
    757
    02:51 AM
    Are you on Subscription? You can get a Reinforcement Add-In through the Extensions available through Subscription Center.
    February 15, 2012
    78
    06:51 AM
    revit extension include reinforcement i know, but i need any other one with more details because that extension not helped me
    for example, i have a continuous beam with different depth, i can't use that extension to reinforcement it because the only case in it for continuous beams is for equal beams in dimension.
    Nantes, France
    1,380
    07:51 AM
    No extension for this yet, except a mouse and a finger or two to click on it :-).
    September 16, 2011
    Perth, West Australia
    138
    02:51 PM
    Hehe, the master teaching that padawan hey Julien. What about the Sofistik plugin, will that handle more complex reinforcement patterns?
    August 4, 2017
    1
    06:51 AM
    HI,
    I need rebar shape image according to ASTM code for REVIT 2018.
    Thanks
    September 3, 2012
    4
    07:51 PM
    check the link on your pc you will find custom rebar shapes.
    C:\ProgramData\Autodesk\RVT 2017\Libraries\New Zealand\Components\34 Steel\34-12 Rebar Shapes
    Senior Member
    December 16, 2010
    845
    04:51 PM
    Sofistik - best reinforcement packacge out there and the only product that offers dynamic structural analysis (as opposed to static) - at least the only product I know of. Its made by engineers for engineers, not by some IT programmer who doesnt know what the industry wants. Very good product but a price to match the quality - keep in mind it is dynamic analysis...
    https://apps.autodesk.com/RVT/en/Lis...query=sofistik
    Also if you use the 2018 revit version you can do reinforcement "by face" for complex shapes - works very well.
    March 21, 2011
    Brisbane
    284
    04:51 PM
    Hi Karalon,
    how well does it produce reinforcement Layot dwgs?
    For example if you have astep in the slab the reo bar has a ,z, end - is that then reflected on the reo plan?
    When using the native Revit tools I have to manually go and add sybols for the un-common bar ends.
    JH
    Senior Member
    December 16, 2010
    845
    04:51 PM
    Yeah I know what you are asking, I can't answer the question for you directly.
    I do know that Sofistik is rolling out in Australia now though, and I can put you in touch with a local tech and they can come and see you if its something that interest you.
    Send me a PM and I can get you in touch with someone that will answer any and all questions for you regarding that program.
    I have not personally used it in production drawings. What I see in most places is that people want reo to stay really productive. So most places I have been at keep producing reo using CAD plugins like BACAD or CADARM to produce the lists in CAD as they are currently adapt at using them and therefore productive. The thing that often is missing in REO schematics are the bending shapes, and tagging and most of this is ready and customisable in sofistik.
    I moved from the Australian market to Europe, and here the drafters go further in the reo detailing that normal structural offices in Oz.
    Here they produce the actual bending, length, and quantity lists to be delivered on site, there in general you are only required to show schematic design.
    As far as I know it will show what you want, but without having used it to produce a working schematic I can't give you a 100% surity on it.
    The real power in it is when used with the analytic module, which is dynamic not static analysis (I'm not aware of many other products that can do this with revit) the bridge module is...astoundingly good...anyhow I like the program the hard part is convincing your engineers/directors to learn it and invest in it as it is an expensive package with the analytic - but the rebar module can model AUTOMATICALLY in 3D straight from the engineers analysis and this will save you untold hours of productivity. I highly recommend you show your engineers and a director, see if they want a demo, then contact me and I will get you in touch with the right people.
    I know one of the developers/engineers and I am sure I can get him to videoconference for you if you like.
  1. Twisted Slab Reinforcement
    By christian0102580 in forum Structure - General Questions
    Last Post: March 5th, 2012, 04:10 AM
  2. Fabric reinforcement
    By phosgore in forum Structure - General Questions
    Last Post: October 8th, 2011, 08:45 AM
  3. Reinforcement In Schedules
    By Ali Akbar in forum Structure - General Questions
    Last Post: May 27th, 2011, 04:16 PM
  4. Path reinforcement
    By XepheX in forum Structure - General Questions
    Last Post: April 14th, 2011, 01:26 PM
  5. Area and Longitudinal Reinforcement
    Last Post: April 11th, 2011, 01:46 PM
