Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree12Likes
Thread: Creating a simple precast family - not so simple!
  1.    #11
    July 7, 2011
    Rotterdam, Holland
    1,277
    08:33 AM
    Oh and was it Revit 2019 that started complaining about dimensions and parameters being attached to model data when you edit a family?
    So even Autodesk thinks it is a bad idea and they still think that importing dwg's is a good idea
  2.    #12
    10,341
    01:33 AM
    It was 2018...
    Robin Deurloo likes this.
  3.    #13
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    02:33 AM
    Quote Originally Posted by Steve_Stafford View Post
    Build the Bones (ref planes/lines), attach Muscle (dimensions/parameters) then add the Skin (solids/voids/lines).
    That is still my favorite analogy for building families!
    cganiere likes this.
  4.    #14
    Orlando, FL, USA
    3,140
    02:33 AM
    Quote Originally Posted by Dlowery View Post
    I sometimes wonder why there are so many techniques for this. I have seen plenty of videos that recommend NOT using reference planes, and currently, my family has none and it seems to work perfectly, not to mention it looks cleaner. I wonder if it's going to bite me later.
    "Plenty of videos that recommend NOT using reference planes?" Where have you been studying about families? It makes a difference what resources you use.
  5.    #15
    August 5, 2019
    9
    06:33 AM
    I have seen Revit families that dimension directly to the extrusion lines in sketch mode. And when I have tried it, it seemed to work well. In fact the only reason I use reference planes/lines now is because everyone says to do so.
    Either way, my real problem still persists. I have not created the family I want yet...
    People have said on here to use assemblies, but I need to have a parameter for unit volume and weight that goes in a schedule, and I am not sure if I can do that since there are multiple units in the assembly.
    What I really want is to have one family with multiple component ends so that I can stretch each dropstem to a reference plane. As it is now, I can snap the component end onto a line or plane, but that's just for the main part of the beam, and that gets cut off anyway. So, all I have to control the dropstems is shape handles, and I cannot stretch them and get them to snap onto a point, which is what need to happen. If I could only figure out a way to get a shape handle to snap to something...
    Attached Thumbnails Attached Thumbnails Creating a simple precast family - not so simple!-5.jpg
  6.    #16
    Mr. Revit OpEd
    2,952
    11:33 PM
    Revit is pretty tolerant of varying techniques for constraining solids/voids. The last few releases have started generating warnings when ill advised constraints exist.
    For each separate form you want to control separately you need a unique parameter (instance to have grips) and a unique Reference Plane or Line assigned to at least Weak or Strong (preset names like Right Left are strong). The preset names allow for dimensions to "jump" from reference to reference. An example is a door family where you apply a dimension to the centerline but can click on the dimension blue dot on the witness line and have the witness line jump to a side...repeat and it jumps to the other side...repeat it returns to center.
    I show in a blog post how a Reference Line and Reference Plane are different as they apply to the display of grips.
    cellophane likes this.
  1. nCr = Simple solutions not so simple
    By snowyweston in forum Dynamo BIM
    Last Post: February 6th, 2019, 06:34 PM
  2. Creating a slope with a simple extrusion family
    By Mr Fooz in forum MEP - Family Creation
    Last Post: January 26th, 2018, 07:12 AM
  3. Simple way of creating Revit Diagrid
    By polyplop in forum Architecture and General Revit Questions
    Last Post: July 5th, 2016, 10:48 AM
  4. Simple drain pan family
    By aykhan9 in forum Architecture - Family Creation
    Last Post: October 16th, 2014, 08:42 PM
  5. Help with creating simple .pat file in notepad
    By maddyjdel in forum Architecture and General Revit Questions
    Last Post: September 8th, 2011, 08:09 AM
