Results 1 to 2 of 2
Thread: Bubbledeck file reduction
  1.    #1
    Lurker
    July 26, 2019
    1
    08:34 AM
    I design and supply a lot of bubbledeck slabs. Customers are now starting to demand that we add the voids/bubbles in our 3D models. This is a brain twister as creating the family model is not hard, but seeing as each sphere is a separate 3d-model, the model size becomes unmanageable.
    I've attached the Bubbledeck family that I created. I tried a test project where I increased the size so that I had around 27,000 bubbles, and the file was choppy and too heavy. However we can have projects where the number of bubbles reach 60-70,000. So my question is if there is any other way to show/model this while still retaining a workable project size? I've all ready tried purging and saving family as compact file.
    P.S. The family is coded in Norwegian, but it is simple wording so just use translate and I'm sure you'll understand the model.
    Attached Files Attached Files
  2.    #2
    December 11, 2010
    Astana
    125
    12:34 PM
    Hi!
    Try to model bubbles directly in the project: Floor + a floor based bubble family arranged manually (temporary arrays) or with Dynamo. Then you can Join them if necessary (structural frame category cuts the floor).
  1. Revit local recovery file significantly smaller than central file after crash
    By techtonic in forum Architecture and General Revit Questions
    Last Post: January 25th, 2017, 09:58 PM
  2. Revit 2015 File - Auditing Local or Central File Leads to Message Stating:
    By nick.atal in forum Architecture and General Revit Questions
    Last Post: May 12th, 2015, 10:13 PM
  3. Duct fittings (reduction offset)
    By bartek_86 in forum MEP - General
    Last Post: January 14th, 2015, 01:54 PM
  4. Building Coder: Basic File Info and RVT File Version
    Last Post: January 24th, 2013, 09:15 AM
  5. Problem in dwg file import Revit then export gbXML file
    By roczhu in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2012, 11:47 AM
