Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Nurlan
Thread: UB with Shelf Angles Family
    August 28, 2014
    24
    11:23 PM
    Hi all,
    How would one approach creating this type of family?
    Please find attached image. I would like to create a structural framing family which has the standard UB serial sizes with option for unequal angles to be fixed to the web at either side. I'd also add the 'X' dimension variable in.
    Would one start with the standard UB family then nest the unequal angle families in?
    Any pointers in the right direction would be appreciated.
    Thanks
    Attached Thumbnails Attached Thumbnails UB with Shelf Angles Family-capture.png
    December 11, 2010
    Astana
    111
    04:23 AM
    Start with UB family.
    Load the angle profile from the angle family.
    Create two constrained angle sweeps.
    Create angle parameters.
    Associate parameters.
    Test it.
    Change your nickname
    BigIdiot likes this.
    August 28, 2014
    24
    11:23 PM
    Quote Originally Posted by Nurlan View Post
    Test it.
    Ha, thanks - i'll give that a try.
    Once i create this family in working order, i'll have earn't the right to change my nick.
  1. Pipe fitting family on different angles
    By Bogey1977 in forum MEP - Family Creation
    Last Post: December 8th, 2018, 09:34 PM
  2. Alive in the Lab: The Pelican Shelf
    By Alive in the Lab in forum Blog Feeds
    Last Post: April 29th, 2016, 11:15 AM
  3. beam with bottom plate/shelf angles
    By stevealey in forum Structure - General Questions
    Last Post: February 10th, 2016, 07:38 PM
  4. UB with shelf angle
    By MartinGT in forum Structure - Family Creation
    Last Post: June 16th, 2013, 01:08 AM
  5. Shelf Increse ?
    By como in forum Architecture - Family Creation
    Last Post: November 16th, 2012, 08:00 PM
