Results 1 to 4 of 4
Thread: Using model data for detail components
  1.    #1
    July 13, 2017
    2
    03:13 AM
    I made a fairly complex baseplate and anchor bolt family that works pretty well for generating a schedule but I would like to take it one step farther. I still end up detailing all the baseplate types by hand and I would much rather have the detail components grab the data from the model. Is this possible? The closest I have gotten us using a legend and faking it to look like a detail.
  2.    #2
    Orlando, FL, USA
    3,001
    06:13 AM
    Welcome to the forum. If you already modeled a complex baseplate with anchors and bolts, what if you make callout views over that baseplate, put dimensions and text and use it as a detail?
  3.    #3
    July 13, 2017
    2
    03:13 AM
    Thanks Alfredo. I think you are right. I'll just work the family a little more so that it looks how I like in a detail view. I was just hoping to find a way that stopped me from needing to create a detail for each new project.
  4.    #4
    Orlando, FL, USA
    3,001
    06:13 AM
    You can still do a parametric detail component of the base plate. It's just that the detail component is not aware of changes in the model as you were asking in your first post. The only connection possible would be through global parameters. Such as: the width of a model base plate family can be tied to a global parameter "Width A", and the width of a detail component base plate family can be tied to the same global parameter.
  1. Help with detail components
    By BoBMudd2 in forum Structure - Family Creation
    Last Post: December 4th, 2014, 08:27 AM
  2. Model-In-Place Component family - Detail Components ask for a workplane?!
    By basilmir in forum Architecture and General Revit Questions
    Last Post: May 24th, 2013, 02:53 PM
  3. Shared Nested Detail Components in Line-Based Detail Components...
    Last Post: December 23rd, 2012, 05:27 PM
  4. Buildz: Adaptive Components: From Data to taDa!
    By Buildz in forum Blog Feeds
    Last Post: September 24th, 2012, 02:15 AM
  5. Detail components
    By bayswater in forum Architecture and General Revit Questions
    Last Post: August 11th, 2011, 04:43 PM
