Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree9Likes
Thread: Copy/Monitor rotates structural column
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    317
    05:08 PM
    Unhappy Copy/Monitor rotates structural column
    Hello everybody.
    I'm struggling with a problem copy/monitoring columns from our structural engineer's model. I've uploaded it here, if you want to replicate the error, do like this:
    • link the file STRUC into an empty ARCH model
    • Copy/Monitor options for columns: Copy original Type, for the rest of the categories: Don't copy this Type
    • Copy/Monitor all the columns from the STRUC model
    • Observe how some columns, not all; are rotated 90 degrees from their original. You can see how the column brackets (is that the term? ) poke out in all the wrong places.... -And i'm not getting any warnings in Coordination Review.
    I'm scratching my head on this one, but my experience with Copy/Monitor is very limited, so i thought you guys might give me a hint before i start pointing fingers at our structural engineers...-i suspect they might have mirrored while modelling?
    Or is it just the whole Copy/monitor process that is flawed?
    I could easily rotate all those columns, but you all know how it is: if I alter geometry, I accept responsibility. And that's kinda the whole idea of copy/monitoring, to keep the responsibility in the right place.
    -Hoping you guys can help, thanks in advance for your time.
    Cheers
    -tue
    Attached Thumbnails Attached Thumbnails Copy/Monitor rotates structural column-1.png   Copy/Monitor rotates structural column-2.png
    Mr. Revit OpEd
    2,832
    09:08 AM
    It's probably because the column was rotated using the Spacebar and the C/M column is placed according to it's origin and orientation. Imagine placing the column yourself. You'd probably have to rotate the column as you place it or afterward to get it in the same orientation. C/M is pretty so/so for such things. I only use it for Levels and Grids personally.
    February 6, 2012
    317
    05:08 PM
    Quote Originally Posted by Steve_Stafford View Post
    Hmmm.....-is there any modelling advice/rules i can impose on our engineers to avoid this? best practice?
    That's depressing.
    As a work-around; would it be possible to copy/paste the columns (or bind link) and then monitor? That way i would get the orientation right, and the monitoring would keep track of the position?
    Orlando, FL, USA
    3,038
    12:08 PM
    What if you don't copy monitor the structural columns and simply use the structural model as the only structural columns? What is the current stage of the project? Maybe you don't need to have two sets of columns at this stage, do you?
    tuekappel likes this.
    Mr. Revit OpEd
    2,832
    09:08 AM
    The original notion of C/M for columns was based on a presumption that architects place columns conceptually where they want them or think they're needed. Then the structural engineer uses C/M to create columns but mapped to place the correct columns types instead. It's a general assumption that other trades merely link structural model into theirs for reference sake, like Alfredo commented.
    There is no need to maintain the Monitored relationship long term as the engineers columns would take over once they've been created and their sizes adjusted for the structural design requirements. If there are pilasters (walls) that mask columns then the architects model would include those (add them to their model) but let the structural model's columns take their role.
    February 6, 2012
    317
    05:08 PM
    What if you don't copy monitor the structural columns and simply use the structural model as the only structural columns? What is the current stage is the project? Maybe you don't need to have two sets of columns at this stage; do you?
    I had the exact same thoughts, since this problem arose. Especially since str. columns are easy to isolate, we obviously don't have any in our ARCH model.
    I just finished a phone conversation with our Revit support, https://nti.biz/, and they found that all the columns that have errors in copy/monitor; at one point have been mirrored. Some even mirrored, and then rotated back :-)
    So thats the "error".
    I'll ask the engineer nicely to model them again without mirroring, and perhaps think twicee about C/M structural columns.....
    Orlando, FL, USA
    3,038
    12:08 PM
    Quote Originally Posted by tuekappel View Post
    But if you simply link the structural model, what's the problem that the structural office rotates or mirror columns?
    LeanneZ likes this.
    February 6, 2012
    317
    05:08 PM
    You're perfectly right.
    If anybody runs into the same problem, and need to report the mirrored elements, i threw together a Dynamo graph to tag the culprits:
    Attached Thumbnails Attached Thumbnails Copy/Monitor rotates structural column-2019-01-08_1156.png
    May 3, 2012
    1,394
    05:08 PM
    I use CM a lot for MEP and have had the same problem. Basically its another of those Autodesk creations that is incredibly powerful and has a lot of potential.... but they didnt bother to fully test it or make a user freindly interface.
    I find that elements not only rotate when first copied, but also when you use Coordination Review. If something has been moved you can choose to move the copied element to the same position, which is pretty much the whole purpose of the CM function. This works perfectly for position but rotation gets screwed up.
    I also use a combination of copy monitor and Dynamo. Unfortunately the CM functions are not yet open to the API, but you can get the copied and linked elements, match the coordinates, then set the correct orientation.
    You can also Un-mirror the elements you have identified as mirrored. Use mirror elements instead of element, as it doesnt delete and replace the original so the monitoring link doesnt get broken.
    The Coordination Review menu is pretty poor and has limited functions, so I might try making a node to parse the report (Such nodes exist already for error reports).
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,060
    12:08 PM
    What packages is the Elements.position-rotation-mirrored from?
  1. How to copy/monitor structural foundation and structural framing?
    By michalnykiel in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 01:37 PM
  2. Copy Monitor Issues w/ Structural
    By nick.atal in forum Architecture and General Revit Questions
    Last Post: May 16th, 2015, 02:24 AM
  3. Copy/monitor slanted column from Struct model to Arch model!?
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: January 13th, 2015, 06:21 PM
  4. Revit OpEd: Changing Column Types and Copy Monitor
    Last Post: December 5th, 2014, 07:15 PM
  5. Copy/Monitor Problem - Conc Column locations from Architect
    By kev4174 in forum Structure - General Questions
    Last Post: March 14th, 2013, 09:31 PM
Tags for this Thread
