Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree9Likes
Thread: Copy/Monitor rotates structural column
  1.    #11
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    305
    04:50 AM
    What packages is the Elements.position-rotation-mirrored from?
    The package called "Elements.position-rotation-mirrored", it has one node, hahaha...
    -It's funny 'cause it's true
    cellophane likes this.
  2.    #12
    February 6, 2012
    305
    04:50 AM
    Quote Originally Posted by josephpeel View Post
    You can also Un-mirror the elements you have identified as mirrored. Use mirror elements instead of element, as it doesnt delete and replace the original so the monitoring link doesnt get broken..
    So basically attaching a mirror node to the columns with Is.Mirrored=True would do the trick? Great!
    I should have thought of that before i asked the engineers' drafsman to redraw the culprits.
    Will test tomorrow at work.
  3.    #13
    May 3, 2012
    1,381
    04:50 AM
    Yes. If you know which elements are mirrored you can reverse the process.
    Although in some cases you may find that you want to unmirror the family (To get rid of the error) but actually it should be the other way around. In those cases you can replace with a different mirror image Type instead.
    I already posted an unmirror script here a while ago (See attached)
    Attached Files Attached Files
    cellophane and tuekappel like this.
  1. How to copy/monitor structural foundation and structural framing?
    By michalnykiel in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 01:37 PM
  2. Copy Monitor Issues w/ Structural
    By nick.atal in forum Architecture and General Revit Questions
    Last Post: May 16th, 2015, 02:24 AM
  3. Copy/monitor slanted column from Struct model to Arch model!?
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: January 13th, 2015, 06:21 PM
  4. Revit OpEd: Changing Column Types and Copy Monitor
    Last Post: December 5th, 2014, 07:15 PM
  5. Copy/Monitor Problem - Conc Column locations from Architect
    By kev4174 in forum Structure - General Questions
    Last Post: March 14th, 2013, 09:31 PM
Tags for this Thread
