Results 1 to 4 of 4
Thread: Too long beams
    October 11, 2017
    2
    08:01 PM
    Too long beams
    Hello!
    I generated steel truss roof in Revit using Dynamo usind standard steel profiles (from autodesk).
    Beams are longer then then should be.
    What's responsible for this behaviur? Why are they going throu another beams?
    see attchments for screen.
    regards
    Orlando, FL, USA
    3,089
    03:01 PM
    Welcome to Revitforum.
    Hard to give any advice based on the information provided. Did you try to do the truss with the Truss tool? I mean, without Dynamo?
    October 11, 2017
    2
    08:01 PM
    Hello Alfredo,
    nope, I did not try truss tool. I want to do all in Dynamo.
    I created similar thread on Dynamo forum, where I found solution (unjoining beams).
    https://forum.dynamobim.com/t/one-st...o-long/28916/3
    Orlando, FL, USA
    3,089
    03:01 PM
    Quote Originally Posted by Nicram View Post
    Hello Alfredo, nope, I did not try truss tool. I want to do all in Dynamo.
    Are these complex trusses that cannot be done with the Truss tool?
  1. Are concrete beams best as slabs or beams should be beams
    By jh75 in forum Structure - General Questions
    Last Post: March 6th, 2017, 09:04 AM
  2. Long section/long profiles section
    By lossbit in forum MEP - General
    Last Post: May 8th, 2014, 01:15 AM
  3. Replies: 0
    Last Post: August 19th, 2012, 07:49 AM
  4. Beams NOT snapping to beams at same elev. but with different ref. plane
    By sebaldsl in forum Structure - General Questions
    Last Post: March 2nd, 2012, 02:01 PM
  5. Didn't Take Long
    By Steve_Stafford in forum Forum Suggestions and Feedback
    Last Post: January 21st, 2011, 12:54 PM
