Results 1 to 9 of 9
Thread: Customize tunnel structural element (new customized family) & analytical properties
    November 13, 2018
    6
    09:37 PM
    Cool Customize tunnel structural element (new customized family) & analytical properties
    Hello, everyone. I am Nan
    I have created one new generic family model(see attachment figure 1) in Revit 2019 and I want to calculate it in SOFISTIK. Thus, in Revit I need the analytical model (3D View in Revit) with clear nodes and lines. So that I can add loads and boundary conditions on the model.
    However, I cannot see the nodes and lines in the analytical model(see figure 1, to make a comparison, I created one wall structural family beside and you can see the nodes and lines clearly). That means I cannot add boundary conditions and loads on the customized generic model. I would like to know, how can I make the new created generic family available to calculation.
    Is there a way to add the analytical nodes and lines in the new created family?
    Actually the new generic family is a part of the tunnel model(see figure 2). To model the tunnel structure, I cannot use the wall or beam family in Revit 2019 to do simulate the whole tunnel. Thus, create a user defined family, not only from the Revit structure family template(wall, beam, brace, etc.), is very important.
    Thanks in advance for your help in advance and I do hope there is a way to deal with the problem.
    Nan
    Attached Thumbnails Attached Thumbnails Customize tunnel structural element (new customized family) & analytical properties-figure-1.png   Customize tunnel structural element (new customized family) & analytical properties-figure-2.png
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    192
    08:37 PM
    I don't know if you want the round tunnel to be analytic? Thats not possible in Revit.
    For your first picture i would use walls and floors to model that, instead of a generic model.
    November 13, 2018
    6
    09:37 PM
    Hello, Jansen
    Thanks for the reply. For the design of tunnel structure, we really need to create our own generic model. Because the walls and floors can not accurately simulate the tunnel structure, especially for some details. If we want to change the parameters in Dynamo in the future, the wall and floor(in Structure) cannot be changed by using Dynamo. This is very inconvenient if we cannot calculate the generic model from ourselves.
    btw, do you know if it is possible to what the code by myself to make some specific revit generic family possible to be analytical?
    Best wishes
    Nan
    December 25, 2011
    The Netherlands
    192
    08:37 PM
    I haven't really searched for it but i have never seen a generic model with analytics in it.
    You can add model lines to your generic model and put them analytic, but they won't export to another program.
    I did a big project where we needed to export Revit models to SCIA and we did a lot of worrkarounds to make the structure. analytical correct so the structural engineer didn't need a lot of time to fix the model in SCIA.
    But in the end some things just don't wanna be analytical in Revit and the structural engineer needs to model the analytical part in his own software.
    Member HansLammerts's Avatar
    April 22, 2011
    451
    08:37 PM
    Hi Nan, Did you take a look at the Sofistik AutoCAD integration? We Use that for more complex bridge analyses.
    November 13, 2018
    6
    09:37 PM
    Hello, Hans
    Thanks for the reply!
    Yes, I know Sofistik and AutoCAD integration and I have tried that before. But to make the BIM workflow more convenient, I need to calculate the Revit model, which means calculate the model from designers directly. That is my purpose.
    November 13, 2018
    6
    09:37 PM
    Hello, Jansen
    Thanks for the suggestion. Could you please tell me more clearly how to add model nodes and lines to the generic model?
    December 25, 2011
    The Netherlands
    192
    08:37 PM
    Nodes are impossible to draw in a generic model, but lines can be done.
    https://www.youtube.com/watch?v=efZTcXGRfXg
    November 13, 2018
    6
    09:37 PM
    Thanks, Jansen. This is awesome!
  1. analytical model in a structural framing family
    By valia in forum Structure - Family Creation
    Last Post: June 30th, 2017, 06:26 AM
  2. Structure family - adding analytical properties
    By Aleksander in forum Structure - Family Creation
    Last Post: May 17th, 2015, 09:12 AM
  3. Customize three different size and materials at Metric Structural Trusses
    By leeway180 in forum Architecture - Family Creation
    Last Post: May 15th, 2015, 04:22 AM
  4. Replies: 0
    Last Post: May 2nd, 2015, 01:18 AM
  5. Analytical properties in gbXML???
    By fpebble in forum Architecture and General Revit Questions
    Last Post: May 4th, 2012, 09:14 PM
