Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By mjajansen
Thread: Span Family with Text/Label
    Member EarthRevi's Avatar
    August 13, 2018
    68
    06:36 AM
    I created a custom span family, because I wont be using the beam system in Revit in certain areas - but I would like the span annotation symbol. The family is working okay, however the text wont drag as I adjust the length of the span. Is there a way to attach a parameter to the text to center of the span symbol?
    Thanks for reading
    Attached Thumbnails Attached Thumbnails Span Family with Text/Label-capture.jpg
    Attached Files Attached Files
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    192
    10:36 AM
    You need to make an extra reference plane where you want the text.
    Then you give the reference plane an continuous annotation and click on EQ, so it stays in the middle of your line.
    Then you need to edit the family of your text and move it to the center of the family, it is a little to the right and up now.
    Then you move the text to your new reference plane and lock it.
    EarthRevi likes this.
    August 13, 2018
    68
    06:36 AM
    This is exactly the outcome I was looking for. I couldn't figure out how to associate text to reference plane. How do I lock text to a reference plane?
    Thank you so much mjajansen
    December 25, 2011
    The Netherlands
    192
    10:36 AM
    If you move the text towards the reference plane you see it ''snap'' and the reference plane highlights a bit. Then you see an open lock, if you click that it closes and your text is locked to the reference plane.
    August 13, 2018
    68
    06:36 AM
    Got it, thanks!!
  1. Partially Bold text in Label
    By jnadel in forum Architecture and General Revit Questions
    Last Post: September 8th, 2018, 07:17 PM
  2. how to rotate text label
    By Ning Zhou in forum Architecture - Family Creation
    Last Post: November 23rd, 2017, 11:40 PM
  3. Vertically wrap all text in a label?
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2014, 08:33 PM
  4. Placing a text label on a component family permanently
    By wiredantiks in forum Architecture - Family Creation
    Last Post: April 25th, 2013, 02:45 PM
  5. Replies: 0
    Last Post: October 27th, 2011, 08:15 AM
