Results 1 to 3 of 3
Thread: Conditional Parameter (Title Sheet)
    August 28, 2014
    24
    08:18 AM
    Hi all, wondering whether anyone could help
    I've steered clear from Revit conditional parameter formatting as I've never really had to use it, however I feel i should know being an experienced user and i also have a situation that i need to sort!
    Could anyone point me in the right direction for my situation below:
    I basically want to link my suitability status to my suitability description in our title sheet, so i want to format the status so it does something like the following:
    If suitability status = S2, then suitability description = FOR INFORMATION
    If suitability status = D2, then suitability description = FOR TENDER
    and so on, implementing the 1192 codes.
    Hopefully this makes sense.
    Thanks in advance
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    03:18 AM
    I don't believe there is a way to do that directly. You will end up needing another parameter since Revit can't evaluate conditional text statements as-is.
    The formula: if(SuitabilityStatus="S2","For Information",if(SuitabilityStatus="D2","For Tender","")) will throw an Improper Use of Boolean error since S2 & D2 are text values. However, if you had a third value that could translate between them it could work, although I think it will end up being more effort than it is worth, and your formula could end being rather long since you need an if() statement for each value you want to display. The attached image should get you headed in the right direction.
    SuitabilityStatus & SuitabilityDescription are both text parameters. Status is an integer.
    edit: All the parameters need to be shared, and the formula has to be in the Label, not in the parameters dialog.
    edit2: This might not work at all I know that using conditionals in tags works, but I'm not getting it to behave in a title block. If anyone else wants to take a stab at it, Title Block is enclosed.
    Attached Thumbnails Attached Thumbnails Conditional Parameter (Title Sheet)-tb-conditionals.png
    Attached Files Attached Files
    Mr. Revit OpEd
    2,910
    12:18 AM
    Another way...
    Attached Thumbnails Attached Thumbnails Conditional Parameter (Title Sheet)-status.jpg
  1. Sheet list - How can I add a circle or dot parameter relating sheet names to phases?
    By yral87 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2015, 07:48 PM
  2. Yes/No Parameter in Conditional Statement
    By keithwales in forum Architecture and General Revit Questions
    Last Post: September 16th, 2014, 05:00 PM
  3. Schedule field color derived from conditional formating, not showing on sheet.
    By Jumle in forum Architecture and General Revit Questions
    Last Post: November 27th, 2012, 05:12 PM
  4. Conditional existence of a system family parameter
    By cbaze in forum Architecture and General Revit Questions
    Last Post: May 10th, 2012, 10:09 PM
  5. "Title on Sheet" parameter field" ?
    Last Post: October 17th, 2011, 12:17 AM
