Results 1 to 3 of 3
Thread: Steel Beams with Wood Nailers
    Junior Member Kate's Avatar
    September 4, 2014
    Ann Arbor, MI
    46
    02:08 PM
    Question Steel Beams with Wood Nailers
    Howdy everyone,
    I'm developing our structural framing families. I'd like to modify our WF and HSS steel beams to allow the modelling of wood nailers on their tops and bottoms.
    My initial idea was to do this without creating duplicate beam families by controlling the nailer visibility with an instance boolean, so where needed the user could enable the nailer and have it appear. The nailer dimensions will also be instance parameters to allow maximum flexibility.
    I created the nailer extrusion without an issue, but it is affecting the behavior of the beam in the model in a way I hadn't expected.
    By default Revit families have framing modeled centered on the reference plane, but when you place beams in models the default z justification is 'top', so beams are shown with their top of steel at the level of the reference plane. (See this link for a bit further explanation / screencast example: https://forums.autodesk.com/t5/revit-architecture-forum/beam-family-help/td-p/5788748)
    Modelling the nailer causes the top of the nailer to be at the level of the reference plane in the project environment, which I don't want. I'd like the top of steel to be at the level of the reference plane - that is, for the beam to act like it doesn't have a nailer on top.
    Is there a way to get the desired behavior without modifying the default z-justification value? Essentially, to 'tell' Revit where the real 'top' of the member is.
    My scheme if that isn't possible is to modify the framing families such that the origin is at the reference level, and then change my z-justification in the project template so that it is set to origin by default, allowing it to work with my custom beam families.
    Attached Files Attached Files
    August 7, 2014
    27
    11:08 AM
    Quote Originally Posted by Kate View Post
    Howdy everyone,
    Make it a nested family. I solved it this way before
    September 4, 2014
    Ann Arbor, MI
    46
    02:08 PM
    Thanks for the suggestion mendler.
    I tried this and it solved part of my issue - when I have the 'nailer' parameter turned off, the top of the beam is at the correct elevation (not being pushed down like it was before).
    However, when I turn the nailer parameter on, it still pushes the beam down by the thickness of the nailer, rather than projecting the nailer above the top of steel. I've attached my modified family with the nested nailer if you'd like to take a look.
    Attached Thumbnails Attached Thumbnails Steel Beams with Wood Nailers-no-nailer.jpg   Steel Beams with Wood Nailers-nailer.jpg
  1. Steel beams & concrete plots incorrect
    By Marco79 in forum Structure - General Questions
    Last Post: May 3rd, 2017, 08:49 AM
  2. Seeing steel beams on angle
    By gazzalp in forum Structure - Family Creation
    Last Post: August 24th, 2015, 09:54 PM
  3. draw I-steel-beams and columns
    By huyvu85 in forum Architecture and General Revit Questions
    Last Post: November 10th, 2014, 04:56 PM
  4. Bent Steel Beams
    By stellra in forum Architecture and General Revit Questions
    Last Post: November 6th, 2013, 09:31 PM
  5. Building Coder: Bevelled Steel Beams
    Last Post: September 5th, 2011, 09:21 AM
