Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Boolean Functions
    April 24, 2018
    31
    04:54 AM
    Boolean Functions
    I am trying to run a Rough Width parameter for different types of doors off of multiple Yes/No functions for door type. I need to make the Rough Width ex: (Width + 1.5") But the '1.5"' will vary depending on the door type. What formula layout must I use for this? I have tried if(Wood, Width +1.5"),if(Steel, Width +2") but I get an error every time. Any help would be appreciated.
    Thank you
    April 24, 2018
    31
    04:54 AM
    To add, I need these all to schedule under "Rough Width" so I am not able to make multiple (1.5",0") statements with a Rough Width 1,2,3.
    December 21, 2010
    Phoenix, AZ
    2,556
    02:54 AM
    You’ll need additional parameters (not text) to differentiate between the constructions and use a nested if statements.
    if(wood,x”,if(steel,y”,z”)
    wood and steel in this example are yes/no parameters — not the best choice but doable
    Dr2430 likes this.
    April 24, 2018
    31
    04:54 AM
    Thanks, I got down the rabbit hole of and's and or's but this much easier
  1. gbXML (& other functions)
    By snowyweston in forum Third party Add-Ins, API and R&D
    Last Post: February 27th, 2018, 05:33 PM
  2. Boolean OR for list
    By ScubaMan in forum Dynamo BIM
    Last Post: September 18th, 2017, 03:14 PM
  3. Losing Tools and Editing Functions
    By JD003 in forum Architecture and General Revit Questions
    Last Post: March 29th, 2014, 10:16 AM
  4. Extended functions for a Keynote Tag
    Last Post: November 22nd, 2012, 12:21 PM
