Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: Tags for custom revit family
    June 9, 2017
    7
    10:23 PM
    Hello,
    I am creating a family for J-hooks for cable management that will array a number of hooks based on the length of a family. It is face associated so it can be placed on a wall or ceiling. I was able to accomplish this, but have run into a problem as I want to be able to tag the family in a project so it will show the elevation and/or type of hook size being used. I think it may have something to do with shared parameters, but am not completely sure. Also, I am struggling to set up a shared parameter for the elevation (can't seem to get away from the default one) and hook size type. I have the different family types available and the modeling aspect seems to work perfectly, it is the tagging I cannot get right. The file is too big to attach, but here is a link to it
    https://drive.google.com/open?id=1n0...k2qTGHIkc9bQjH
    If anyone can help, it is much appreciated.
    Thanks!
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:23 AM
    Hi there,
    First I'd like to start with mentioning that you used an imported symbol for the geometry, probably some imported dwg. This in my opinion is way to detailed and will slow down you project when you have a couple of 100 of these in there. Build your own geometry, from just 1 simple Sweep and you have the basic shape at the right size without all the little nooks and details, I mean do you really need the manufacturers info modelled in there?
    To get the right J-Hook in your tag I would make different Family types. For each type you choose a different J-Hook with the Parameter you already have and fill in Parameters like Description and Type Comment for each type. So you will end up with 1 Family called J-Hook for example, with in your case 5 types called:
    cat16hp - 1in dia
    cat21hp - 1.3125in dia
    cat32hp - 2in dia
    cat48hp - 3in dia
    cat64hp - 4in dia
    You place the names of the type of J-Hook in the Description of the different types in your Family and you can build a Tag that reads and displays that Description.
    For the height, I don't believe you can read and display the Elevation in a Tag or Schedule and this is why I have added a Height Parameter to some of my Families. You would have to set the build-in Elevation to 0 all the time and use your own Height Parameter. Not perfect, but for me it works because it is just me using them. If you works with multiple people in your company then maybe it would not.
    But you should be able to make a Dynamo script that changes the values, reads the Elevation value, sets it to your Height Parameters and sets the Elevation to 0 for all the families at once. That's one I'm going to give a shot myself now I think about it.
    cganiere likes this.
    June 9, 2017
    7
    10:23 PM
    Quote Originally Posted by Robin Deurloo View Post
    Hi there,
    cat16hp - 1in dia
    cat32hp - 2in dia
    cat48hp - 3in dia
    cat64hp - 4in dia
    Thank you! I was unable to make it read elevation off of a height parameter, cause I cannot figure out how to get this to work when making a face based family as there is no base elevation to work from like a wall based family has. We want to be able to put them on either the wall or ceiling so I need to use face based. Here is the link for the simplified model (note: the box extrusion is because my boss wanted to be able to see it that way when in coarse/medium detail level).
    If you are able to get this working with dynamo or have any example you could give of making the height parameter work on a face based family, could you please share?
    Thank you
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:23 AM
    Here is your own family back with the height parameter.
    Quick and dirty and I think I might have broken you array, but you'll get the idea.
    For it to tag of read in a schedule you need to make it a shared parameter.
    For on a ceiling I don't know. This is the reason I made my fire safety families as unhosted and just type in the height I need them to be.
    I might look into Dynamo for this at some point, but right now I have no time digging into it. Just a few more weeks and I have some free time (I hope).
    Attached Files Attached Files
    June 9, 2017
    7
    10:23 PM
    Thank you Robin! I'll have to ask people I'm working with which method they prefer because of the ceilings. I'm trying to start learning how to use dynamo myself as I've never used it before, but it seems like it has the potential to be very useful. Just need to find free time like you.
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:23 AM
    Dynamo is fun to use, but it is always a balance on how much time would it cost me to build in Dynamo and how much time would that save me on a project (every time). Being a 1 man shop myself a lot of the dynamo stuff is not really worth it for just 1 time use compared to having multiple people use the same graph multiple times. But for example having a Dynamo graph for creating levels, views and sheets is very useful and changing stuff in titleblocks for example, especially when you have a 100 of them like I have on my current project. And once in a while I just build it in Dynamo because it is fun to do .
    Still have a Dynamo Enigma Machine I need to finish one of these days
  1. Revit Kid: Revit Tutorial - Custom Shaker Cabinet Family
    By The Revit Kid in forum Blog Feeds
    Last Post: March 16th, 2016, 12:15 PM
  2. editing family room tags
    By sgray05 in forum Architecture - Family Creation
    Last Post: October 21st, 2014, 05:29 PM
  3. Custom Wall Tags? or Best Practice
    Last Post: March 30th, 2012, 04:39 PM
  4. Custom Annotation Tags
    By MPwuzhere in forum Architecture - Family Creation
    Last Post: March 26th, 2012, 02:59 PM
  5. Custom View Tags. Help Please
    By drafterjohn in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 09:55 AM
