Results 1 to 4 of 4
Thread: Switching between family types in a Project
    June 9, 2017
    7
    01:16 PM
    Hello,
    I was practicing making a simple family with different family types for sizes and have run into an issue. When I am editing in the family, changing the type changes the sizes according to the parameters assigned to the different types. However, when I load the family into a project, the different types are available in the component properties drop down menu, but once a component is loaded in to the project and in place, I cannot swap between the two family types. It will switch over in the properties tab, but it doesn't actually change. I have tried locking the parameters inside the family and that does not work either. What could be wrong?
    I have attached the file I am using to explore his issue I am having.
    Attached Files Attached Files
    Coeur d Alene, ID
    4,784
    10:16 AM
    Your parameters are instance and not type...so instance parameters are modified in the properties window within the project vs selecting a type.
    June 9, 2017
    7
    01:16 PM
    Ok thank you! This fixed it. So anything I want to be individually adjustable (height, depth, etc) could be instance, but for making set family types, use types?
    Coeur d Alene, ID
    4,784
    10:16 AM
    Yep...But sometimes keeping some items instance helps cut down on the amount of types...such as doors.
  1. Replies: 0
    Last Post: May 13th, 2016, 08:45 AM
  2. Get a list of all family types in project
    By engineer in forum Dynamo BIM
    Last Post: April 1st, 2016, 07:07 PM
  3. Cycle through Family Types in Project Environment - Still Possible?
    By Andrew K in forum Architecture and General Revit Questions
    Last Post: November 30th, 2014, 05:04 PM
  4. line types not scaling from family to project
    By joewallace in forum Architecture and General Revit Questions
    Last Post: July 9th, 2014, 11:54 AM
  5. Replies: 0
    Last Post: December 4th, 2013, 10:15 AM
