Results 1 to 2 of 2
Thread: scissor truss with flexible overhang
    November 28, 2011
    Ontario, Canada
    153
    11:19 PM
    Hello All,
    I have a project that is using a scissor truss and the tech who created the project just used an OTF truss family. the arch wants the scissor truss to show as the shop drawings. I have created a custom scissor truss (see attached-family is in revit 2018) and everything seems to flex ok with the exception of the following.
    1. for the overhang: i am not sure how to get the top chord to be flexible meaning the roof will have some jogs but the slope obviously needs to stay the same.
    2. as you will see on the right side i have two vertical web members, if i adjust the width of the truss or overall height, the horiz position will follow the reference planes but the either the top or the bottom of the vert web member will not stay joined where the diagonals meet. i tried locking but that didn't seem to work.
    so i am a little stumped. I wanted to create a flexible family as I was told we will have about 3 more projects similar to this one and the arch wants to show the truss es when IFC are issued.
    Thanks in advance.
    Regards,
    Kevin
    Attached Files Attached Files
    December 11, 2010
    Astana
    116
    09:19 AM
    I recommend that you first use Reference Lines, and then add the truss elements and constrain them to the RL frame.
    See the attachment, the numbers indicate the order of creation.
  1. Stair Nosing at Landing will not overhang
    By billiam in forum Architecture and General Revit Questions
    Last Post: January 31st, 2017, 07:25 PM
  2. Roof Overhang Issue
    By D_Incognito in forum Architecture and General Revit Questions
    Last Post: August 31st, 2016, 10:41 PM
  3. Flexible Slab Edge
    By Vanguard in forum Structure - Family Creation
    Last Post: March 7th, 2014, 02:10 PM
  4. roof overhang grayed out
    By ChrisInTexas in forum Architecture and General Revit Questions
    Last Post: February 17th, 2014, 11:25 PM
  5. Roof partial overhang
    By boembab in forum Architecture and General Revit Questions
    Last Post: February 12th, 2014, 05:16 PM
