Results 1 to 1 of 1
Thread: Revit Rebar Detailing
    New Member Marmite_Monster's Avatar
    June 22, 2018
    Nottingham
    2
    04:47 PM
    Hi All.
    I have a couple of things I would like help with if possible.
    I am using v2018. I do not have any add-ons for rebar detailing.
    Is there a way to lock the rebar numbers that is automatically generated? I detailed and scheduled a wall only for it to be changed. When altering some of the bars revit decided to re-number some bars. Fortunately no schedules had been issued for construction.
    The other thing is I would like to create a tag showing the extent of a rebar in section. I can create a tag with the bar mark and an arrow pointing to the bar but I would like another that a can attach to each end of a bar to make it clearer in section where the bars are placed. See attachment. At present I have to add manually and need to change if revit decides to re-number!
    Any help/tips much appreciated.
    Attached Files Attached Files
  1. Rebar Detailing
    By Talha Kadwa in forum Structure - General Questions
    Last Post: February 22nd, 2017, 07:57 AM
  2. Replies: 0
    Last Post: February 5th, 2016, 12:15 PM
  3. Revit Rebar detailing
    By vivek in forum Structure - General Questions
    Last Post: March 23rd, 2015, 03:27 PM
  4. Beginner type questions - rebar detailing
    By rebar_detailer in forum Structure - General Questions
    Last Post: January 9th, 2012, 02:19 PM
  5. Rebar Detailing
    By gdoherty0102 in forum Structure - General Questions
    Last Post: January 19th, 2011, 06:54 PM
