Results 1 to 4 of 4
Thread: Complex Truss- Analytical lines
    December 20, 2010
    1,057
    12:32 PM
    How do I add analytical lines to a truss shape that was started using the structural framing complex template? the truss contains double c shape beams for the top chord, then double horizontal L's for the tie beam, with a tie rod in the middle and parallel to the top chord beams.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    12:32 PM
    Why did you use the complex template instead of a typical truss family? I'm genuinely curious because I don't make many structural families so other than I've figured out just stabbing blindly at the family don't really know the difference, other than one of them seems to not have an analytical model.
    December 20, 2010
    1,057
    12:32 PM
    typical truss family has no geometry only lines and this is a very complex truss (at least in my opinion) see image.Complex Truss- Analytical lines-truss.jpg The top chord is double C channels with 1" gap with tie rods in the gap, then double angles part way up. Arched Rolled inverted T shape arch, etc.
    August 9, 2011
    Louisville, KY
    6,140
    12:32 PM
    You would need to make some custom beams to account for the double members but getting that truss isn't hard from a Revit standpoint other than the constraint math could be ugly (mine is super ghetto and not really correct )
    Whether it is correct is a different issue altogether
    Attached Files Attached Files
  1. Truss looking like lines in elevation
    By piper76 in forum Structure - General Questions
    Last Post: October 10th, 2016, 06:51 AM
  2. Analytical column
    By sink69 in forum Structure - Family Creation
    Last Post: April 11th, 2015, 05:03 PM
  3. analytical of beam
    By huyxp in forum Structure - General Questions
    Last Post: July 12th, 2013, 05:44 PM
  4. Analytical model
    By jbenoit44 in forum Structure - General Questions
    Last Post: June 21st, 2012, 03:34 PM
  5. Analytical Model Lines
    Last Post: December 16th, 2011, 10:18 PM
