Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree2Likes
Thread: Family with several beams and columns
  1. #11
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    04:05 AM
    Until the wood comes in a different profile.
    To clarify (for Harnta): material (parameter) tieing is entirely possible, parent-to-child.
    Profile without only with and height is possible with shared parameters.
    Verstuurd vanaf mijn Moto G (4) met Tapatalk
  2. #12
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    04:05 AM
    If you share de parent family with children I look into it this weekend. I think you need to contect the dimension of de beams en columns into the parent so every different beam en columns has his parameters (so you get a lot off them) and they have to be shared parameters. (Else they do not show in the schedules)
    Good luck to you I hope to see a nice family.
  3. #13
    April 7, 2018
    5
    02:05 AM
    I still don´t get it. Now I have made a material parameter and a shared parameter called L. If I load this column into a Project I still don´t get the length when Schedule, but I can get the length with my own shared parameter L. What am I missing?
    Attached Files Attached Files
  4. #14
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    04:05 AM
    Text Parameter Properties.
    Family parameter (Cannot appear in schedules or tags)
    Shared parameter (Can be shared by multiple project and families, exported to ODBC., and appear in schedules and tags)
    It is the revit way to get it. I think you need to add a lot of parameters....
  1. draw I-steel-beams and columns
    By huyvu85 in forum Architecture and General Revit Questions
    Last Post: November 10th, 2014, 05:56 PM
  2. columns and beams not showing in section
    By joewallace in forum Architecture and General Revit Questions
    Last Post: May 4th, 2013, 09:53 PM
  3. Cant load structural beams and columns..
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: January 7th, 2013, 04:14 PM
  4. Beams & columns
    By narlee in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2012, 08:10 PM
  5. OOTB Content for Beams/Columns
    By TheViking in forum Structure - General Questions
    Last Post: May 7th, 2011, 04:57 AM
