Results 1 to 6 of 6
Thread: In 3d view rebar family display in a single line
    February 19, 2018
    Sri Lanka
    14
    10:39 PM
    In build rebar family or created rebar family does not display in 3d view correctly.
    It display as a single line. How can I correct the family to display as a real steel bar in
    3d view.
    Attached Thumbnails Attached Thumbnails In 3d view rebar family display in a single line-rebar-family.png
    June 21, 2012
    Tours, France
    937
    06:54 PM
    Quote Originally Posted by wimal View Post
    3d view.
    Hi, that's normal, you need to go to your properties pallet and once there look for the graphics section, once there you need to click on the modify button and inside there you need to look for 3D view and activate it, see image, hope this can help you , regards
    Attached Thumbnails Attached Thumbnails In 3d view rebar family display in a single line-visibilite-structure-3d.jpg
    February 19, 2018
    Sri Lanka
    14
    10:39 PM
    Not only that. I had to change view template also.
    Thanks ANDRES
    Attached Thumbnails Attached Thumbnails In 3d view rebar family display in a single line-view-template.png   In 3d view rebar family display in a single line-rebar-family.png
    February 19, 2018
    Sri Lanka
    14
    10:39 PM
    This image attaching for English readers
    Attached Thumbnails Attached Thumbnails In 3d view rebar family display in a single line-rebar-view.png
    June 21, 2012
    Tours, France
    937
    06:54 PM
    Thanks ANDRES
    That's entire on you , but yes I guess changing the view template can save you more time , most important thing is you have your solution!! , regards
    March 5, 2019
    1
    04:54 PM
    thanks
    Thanks ANDRES
    Thanks it helped .
  1. help to display pipe with with only single line
    By trang_chau in forum MEP - Family Creation
    Last Post: April 18th, 2016, 02:13 AM
  2. color display for 3d hidden line view
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 07:14 PM
  3. Railings set to Single Line in Plan View?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: March 21st, 2013, 10:07 PM
  4. View Port labels that are a single line and do not wrap
    By lacrosseplayr978 in forum Architecture and General Revit Questions
    Last Post: September 13th, 2012, 01:14 PM
  5. single line display issue
    By RStiles in forum MEP - General
    Last Post: July 9th, 2012, 10:54 PM
