Results 1 to 4 of 4
Thread: Nested family flexibility
    November 2, 2017
    5
    10:20 AM
    Hi guys,
    can anyone give me an idea about how to change/update sizes for nested family, the nested family already has size control parameters.
    is it possible to do that? I have searched online a lot but haven't found anything regarding this yet.
    Thanks in advance!
    December 21, 2010
    C.LONDON
    4,382
    10:20 PM
    "depends"
    If it's a shared child the child's parameters need to be instance so you can directly tie them.
    Unshared, which are "only" good for building (read: otherwise useless for downstream use) then you can tie instance and type parameters
    There's also "just" swapping children within parents using type-selectors, shared and unshared children both work, but offer different levels of flexibility accordingly
    Some familiy categories are more restrictive than others for parent/child driving, same goes for the templates used to build them, and bear in mind some of the OOTB instance parameters (like <Mark>) can be tied, but don't behave (when tied) as they should... similarly, be aware some parameters (like <Type Mark>) are only exposed once in project.
    so with those fundamentals covered, what is it that you're trying to achieve?
    November 2, 2017
    5
    10:20 AM
    I have figured it out, thanks, snowyweston
    you are right, the child's parameters need to be instance and just tie them....
    November 2, 2017
    5
    10:20 AM
    [QUOTE=snowyweston;200003]"depends"
    how does this one work, and if child's using type parameter, how to tie the parameter?
  1. Replies: 0
    Last Post: March 16th, 2017, 03:15 AM
  2. Template Flexibility
    By mdomer in forum Architecture and General Revit Questions
    Last Post: April 21st, 2016, 11:05 PM
  3. Detail Family Flexibility with Grips Solved?
    By JWelsh1990 in forum Architecture and General Revit Questions
    Last Post: February 12th, 2016, 09:20 AM
  4. Replies: 5
    Last Post: November 13th, 2014, 08:00 PM
  5. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
