Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree4Likes
Thread: Revit extrusion doesn't align with profile lines properly.....
    Member mark2009's Avatar
    May 27, 2015
    106
    09:54 PM
    hey guys, is there a simple fix? so the extrusion lines are aligned with the profile lines.
    Attached Thumbnails Attached Thumbnails Revit extrusion doesn't align with profile lines properly.....-line-alinged-gliched.jpg
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    02:54 AM
    It looks like Revit is approximating the curve with segmented lines. I make a lot of extrusions from profiles and have never seen this before. Any chance that you could post the profile to play with?
    edit: another thought, what is your rounding set to in your family project units settings?
    May 27, 2015
    106
    09:54 PM
    cheers for the reply, the solution that i use is using a spline tool and making it close as possible.
    May 27, 2015
    106
    09:54 PM
    ive tried changing the rounding to the nearest 1000 then realigning it. but didn't do anything.
    May 27, 2015
    106
    09:54 PM
    here's profile best of luck.
    Attached Files Attached Files
    Dave Jones's Avatar
    4,486
    02:54 AM
    Quote Originally Posted by mark2009 View Post
    I'll play with that and see what I come up with. To verify, you are using the profile in a GM family to make an extrusion, right?
    edit: oops, I can't help as I don't have R2018 installed here
    May 27, 2015
    106
    09:54 PM
    what version are you using? profile was created in dwg which is loaded in GM
    10,036
    04:54 AM
    That right there is more than likely why you're seeing issues with it.
    Aaron Maller
    Director
    Parallax Team, Inc.
    May 27, 2015
    106
    09:54 PM
    Tbh, just extrusion in auto, or inventor then explode it in revit
    Dave Jones's Avatar
    4,486
    02:54 AM
    ACKK! create a profile family, import CAD, create Revit linework over the CAD import (do not use Pick Lines!). Copy/paste the Revit linework to another clean Revit profile family then use that in your GM family.
    uaifestival and cganiere like this.
  1. How do I lock and align the second extrusion to move with the first
    By sambarr88 in forum Architecture - Family Creation
    Last Post: October 1st, 2018, 04:55 PM
  2. Profile Hosting in a Sweep Extrusion
    By cftrevizo in forum Architecture - Family Creation
    Last Post: December 22nd, 2017, 05:24 PM
  3. Align dimension not working properly
    By perewesley in forum Architecture and General Revit Questions
    Last Post: September 5th, 2017, 02:09 PM
  4. Sloped door entry way which cuts into sub-floor doesn't display properly
    By lukewallace1990 in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2013, 10:44 AM
  5. Wall made from mass doesn't work properly
    By arch.danieldoi in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 08:04 AM
