Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Nestled family does not control the visibility
    November 21, 2017
    8
    01:24 PM
    Angry Nestled family does not control the visibility
    Dear forum members,
    Hope you guys have an solution for this.
    I'm struggling with the visibility parameters. I have 1 host family with an nestled family in it.
    The nestled family controls 4 object (visibility on/off depending on length)
    The host family controls the nestled family (simple yes/no checkbox parameter)
    When i use the "preview visibility mode" in my host family, everything works fine. Depending on length (1572 / 2072 / 2572 / 3072mm ) and length different then those 4, the nestled family keeps invisible.
    But when i use the host family in an project, the nestled family visibility parameters doesn't work. I added my project file, sample project and host family in it. Maybe you guys see the problem.
    Thanks for the help.
    ( out of the box question, can i make an z justification parameter fixed to origin? thanks )
    Attached Files Attached Files
    December 21, 2010
    Phoenix, AZ
    2,556
    05:24 AM
    I don’t have an answer... just wanted to say I love calling them nestled... sounds so comfy in there!
    Dave Jones likes this.
    November 21, 2017
    8
    01:24 PM
    Quote Originally Posted by Erdem01 View Post
    Dear forum members,
    Can anyone help me out with this? Only 1 member checked the family
    May 4, 2011
    110
    08:24 AM
    I don't think you can have the nested family reevaluate the visibility parameter dynamically like that. Instead, put your visibility formula at the parent family level and then link the 4 visibility parameters together.
    L.A. Ligger:
    DB_157 -> Formula: Length = 1572mm
    DB_207 -> Formula: Length = 2072mm
    DB_257 -> Formula: Length = 2572mm
    DB_307 -> Formula: Length = 3072
    In the DB ligger totaal.rfa,
    remove all the formulas. Load back into LA Ligger.
    Select the instance, and tie the 4 visibility parameters together.
    November 21, 2017
    8
    01:24 PM
    Quote Originally Posted by flayre View Post
    L.A. Ligger:
    Thanks a lot!!
    I assumed that you can not control two visibility parameters for the same family, but you linked one visibility parameter. Stupid me.
    I appreciate it
  1. Visibility Control not working in Project
    Last Post: June 2nd, 2017, 02:22 PM
  2. Which is the best way to Control Visibility?
    By amarkrish108 in forum Architecture and General Revit Questions
    Last Post: December 14th, 2016, 01:28 PM
  3. Control family visibility with shared project parameter
    By Carchee in forum MEP - Family Creation
    Last Post: June 24th, 2016, 09:13 PM
  4. Control revit visibility
    By Somaya in forum Architecture and General Revit Questions
    Last Post: February 11th, 2016, 08:19 AM
  5. Text notes visibility control
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 21st, 2012, 04:23 PM
