Results 1 to 5 of 5
Thread: Constraining a sweep extrusion using an angle parameter
    February 22, 2017
    6
    04:26 PM
    I have created an angled bar with an angle parameter. I have managed to get it so that both the bar angle, and the void holes in the bar both move with this parameter. I also have a second sweep extrusion in the shape of a hoop I would like to move along with it, but no matter what I align or try and snap to, it breaks the constraints.
    Any ideas? File attached for clarity, it should make clear what the issue I have is if you adjust the angle parameter by 10 degrees or so.
    Thanks
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:26 PM
    switching the loop to a face-based family will help. I also added a reference line to constrain it's location.
    February 22, 2017
    6
    04:26 PM
    Thanks for the quick response! That's exactly what I need.
    For my own understanding, did you have to create a separate face-based family and load it in, or can you just model-in-place a component?
    I'll give it a try tomorrow! Cheers
    August 9, 2011
    Louisville, KY
    6,104
    12:26 PM
    I made a separate family, using the Generic Model-Face Based template and nested it.
    February 22, 2017
    6
    04:26 PM
    Great, thanks for this!
  1. Constraining the Input Value of a Parameter
    By denden in forum Architecture - Family Creation
    Last Post: June 27th, 2017, 10:24 PM
  2. Constraining nested family to angle parameter
    By theoryshaw in forum Architecture - Family Creation
    Last Post: June 23rd, 2017, 07:15 PM
  3. Length of sweep extrusion in schedules
    By Jdcfrench in forum Architecture and General Revit Questions
    Last Post: March 18th, 2015, 08:56 AM
  4. Angle Constraining option - Revit 2014
    By sabari2504 in forum MEP - General
    Last Post: March 24th, 2014, 12:34 PM
  5. single parameter re-size sweep-blend based on locked angle constraints
    By aheintze in forum Architecture - Family Creation
    Last Post: August 1st, 2012, 03:07 PM
