Results 1 to 2 of 2
Thread: Hide / Delete Project Parameter
    August 8, 2017
    1
    10:54 AM
    Hello,
    Long story short: I am testing out Revit with the Autodesk Forge Viewer and I want to (because of the UI) customize the Properties Parameter Data, and create my own Groups (categories) and Instances. This is why I want to delete or hide these parameters..
    Kindly see attached photo for an illustration related to which parameters I want to modify (Constraints, Construction, etc..)
    Is this possible?
    Attached Thumbnails Attached Thumbnails Hide / Delete Project Parameter-rev.png
    Senior Member
    December 16, 2010
    849
    08:54 PM
    Im going to say no, because these are parameters coded into the basic family templates. If these had been added parameters you could remove some of them, but in most cases here that you have highlighted the answer is a pretty solid no.
    You can still edit those families to create your new categories you wish to see however. But those Baseline ones will always be there.
    If you want these to go away you could export to IFC and you might lose a bunch of them...but this is a hack, and an ugly one.
  1. Hide/Show Parameter
    By aykhan9 in forum MEP - General
    Last Post: June 5th, 2014, 11:03 AM
  2. Hide Mass Grid Lines in Project
    By Shields08 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 10th, 2014, 11:42 AM
  3. Delete a Parameter in the Edit Label
    By dsd in forum Architecture and General Revit Questions
    Last Post: April 18th, 2014, 03:17 PM
  4. how to show and hide (or delete) some face/sketchplane
    By kukuzry in forum Third party Add-Ins, API and R&D
    Last Post: June 27th, 2013, 09:30 PM
  5. Cannot delete family in project
    By ParagonChris in forum Architecture and General Revit Questions
    Last Post: June 20th, 2012, 11:56 AM
